Rb26 Cam Covers Timing Cover Valley Cover
By pacman_1219 · Posted
Update Got turbo back from hypergear, installed everything etc. Bled coolant, wasn't smoking so I thought beauty she's sorted now. Went on a drive, car up to temp, let it idle for about 15 seconds, gave it some gas...nice puff of smoke again. Fml No doubt my turbo was pretty worn anyway but nonetheless frustrating that the problem persists. -
Lol, yeh sure. But I'm not changing the head on this engine. Turbo is the current mod im looking at; as the VCT-2.6L engine im building is getting the turbo setup i posted so the old built RB25DE needs a snail
New setup just needs a VCT enabled head and it will come on so much earlier. At least 500rpm of added response, if not more. -
Wow, there's a user name I haven't seen for a while! Good to see you back @Sydneykid
Something to note, on an aftermarket BOV, it's quite possible to end up with the worst of both worlds, where on light throttle, there isn't enough force to open the BOV so you get small reversion and driveability issues, and with the venting to atmosphere, it dumps a lot of fuel on shifts. Realistically, dumping to atmosphere under power isn't a major driveability issues, compared to the issues of stalling from reversion. If you're getting up the throttle, then putting the clutch in, say on a shift up, but then don't release the clutch, yes, the engine can and will stall, but, just drive around it, and that's easy, let the clutch out in the next gear and the car rolling will keep it all running / going.who wants a hard hit of throttle and then to just let the motor idle anyway? Main issue for driveability is blipping throttle and it wanting to stall, like when parking or trying to move in slow traffic.
