Hey guys
Just thought i would post up and let you know of what a brilliant experiance i have been having with my workshop and tuner Paul Fisher at Pulse Racing Menai.
I recently put my BCNR33 in for my stage 2 mods which include:
nismo fuel pump
nismo 600cc injectors
Z32 AFMs
HPI dump pipes
2860-9 turbos
HKS actuators
And after running into a few problems with my cat being screwed the car was back on the dyno and pulling healthy numbers.
Not only is Paul a great tuner but a great person to deal with and spends that little extra time to explain what is happening with the car and always happy to answer any questions i may of had.
The guys and at Pulse Racing show real pride in their work and it shows in the end result.
I would have no hesitation in recommending Pulse to anyone with a performance vehicle.
I am noway affiliated with Pulse racing and being paid or discounted for this testimony, just wanted to pass on helpful information to other enthusiasts!!!
And here is the final result:
Very happy with the result and above my expectations, drives great with heaps of torque
a very happy customer!!!
Nick
https://www.sau.com.au/forums/topic/368510-stage-2-complete/
Have you got a print out of the boost response? Just wondering when it hit full boost. Very nice results though! Was thinking of changing my -7s for -9s myself. Post your results in the rb26 thread too!
here you go running more then what people would recommend but is still safe :)
Paul has a superb reputation with guys on Rexnet and Ozfoz too, and deservedly so (after working on those finicky WRX engines). :thumbsup:
His manner, communication skills and expertise are very similar to Yavuz at Unigroup Engineering. :thumbsup:
Hey guys
Nick
Am I reading the torque curve right - 7000 nm on a 2.6 RB? Wow if that's correct very impressive.
  • 2 months later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
