evening all,
looking at upgrading my AV in the comming weeks. and on the lookout for a new spyware aswell.
currently running AVG free/ Ad-aware / malwarebytes, but AVG its getting a bit sloopy, and i've had troubles with ad-aware detecting game files as spyware.
so i'm curious as to what everyone is using and their opinions of them are.
https://www.sau.com.au/forums/topic/368515-anti-virus-spyware/
I use Symantec Endpoint Protection (would not touch any norton / symantec consumer product) and Malwarebytes.
For a free AV, I've seen AVG let too many things in and alternately find too many false positives on computers I've fixed, don't mind Avira / Avast though.
Microsoft IMO have the best product out in terms of invasiveness - it simply isn't :)
Microsoft Security Essentials. Been using it now for 18 months without an issue. Auto updates, auto scans and best of all it is not a CPU hog. I can happily use on my PC with it fully activated and running scans and notice no impact.
Also uses the lowest resources of most free virus scanners.
It also integrates with MS Security centre on your PC and doesn't overlap etc. Never had a false negative, never had it stop me from doing anything but then i do use my PC as an Admin given I'm Win7 Ultimate.
Recently my brother actually had issues with AVG IIRC, it was stopping his utorrent client intermittently for some dumb reason. Soon as it was removed and replaced with MSE - problem gone.
i run nothing so far i have found that to be quick and effective ;)
i don't go looking for cracks of any sort and i don't bear-share or any of that crap i don't click weird links in emails or msn
your obiously not looking at enough porn. :P
your input is much appreciated guys :)
I ran nothing for the best part of 4 years simply because everything else was too intrusive/took up too much resources etc.
Hence I went with MSE once it had a bit of market penetration/review etc.
You can watch porn till the cows come home and not get a virus. You could click a kiddies site and get one.
It's all about the sites you visit and then the links you click.
I run PeerBlock with full lists activated as well which is also a very good compliment.
Still lets me use SAU, Facebook. Only common site i use that it blocks is GMail/Google searching. But you can just cancel specific lists if it gets too intrusive.
MSE is not an enterprise product though, its for the average joe home user. Not a company that is prone to far wider and more dangerous attacks.
If an organisation did as such, then they are simply retarded and deserve it.
TBH i don't trust any.
No anti-virus will ever be 100% fool proof though unless you have total lock-down which then allows users to not do a thing.
My workplace is semi-like that and no word of a lie, when the scan runs daily, you cannot use the PC for an hour due to a crap implementation.
So I just pull the plug and reboot it lol. The scan isn't intelligent enough to realise it never finished (our desktop guys make me laugh almost weekly) ;)
End of the day anyone relying on anti-virus as a home user to 100% protect them is kidding themselves as no anti-virus will protect you from clicking a bogus link in an email/website.
Yet most average users assume this to be the case unfortunately.
The more invasive a anti-virus is, the more it will piss you off and you'll end up cancelling the alerts so often that you'll be caught out anyway :)
Has anyone ever thought that it's maybe the antivirus companies that create many (not all) of the viruses?
I'm with Madaz on this. If you know what NOT to click and which programs to execute, then you won't find a problem.
I was having more problems whilst using antivirus than not.
That being said, I don't leave my PC on 24/7 to constantly run torrents. It only gets turned on when it's being used.
Outpost Internet Security Pro on the home PC.
Have run it for a couple of years now and found it to be better than anything I had in the past.
MSE at work.
[quote name=ClutchBurndout-:(' timestamp='1308706438' post='5877233]
i havnt had any antrivirus on my pc in ages
but then again i dont go visiting hardcre gay porn sites like the rest of you
So you say :rolleyes:
+1 for home use. lovin it.
SEP11 for enterprise though as was stated by other people.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
