hey,
only if your bored and over 18, go to these websites, really funny
http://www.bostonpparty.org/personals.htm - dont look at the pics, but read it,
http://www.bullguard.com/badnews/ dont know if its real, but funny.
http://cardrift.com/dodge.html - the best i got was 20 odd seconds.
http://games.eof.net/ashke/pingwin1.swf - pingwin returns.
http://pettipond.com/laterimages/pinups/je..._62/pinup62.htm - no comment
all from orsm.net
matty
https://www.sau.com.au/forums/topic/36853-sick-but-funny-stuff/
