As many of you are aware Kumho through their NSW distributor Fsport have generously provided sponsorship for this years lap battle championship. They are offering 3 forms of support:
1. A $1000 voucher towards the purchase of 4 motorsport tyres for the eventual winner of each class of the championship (3 vouchers total).
2. Three $500 vouchers - 1 per class - towards the purchase of 4 motorsport tyres awarded per event, drawn at random from the financial members of RENEW and SAU NSW. You don't need to have the fastest car to win this prize, you just need to support your club through membership and attending events. If you intend on entering multiple events it's cheaper in the long run to become a member too (9 vouchers total).
3. A discount to any competitor purchasing new motorsport tyres through Fsport. Simply mention that you are a competitor in the Kumho lap battle championship when you speak to John.
The winners for the $500 vouchers for rounds 1 and 2 are
Round 1:
Eric Yamashita – Street
Ben Martin – Open
Trent Kennedy – Club
Round 2:
Mike Bennett – Street
Dale Green – Open
Mark Robinson – Club
Congratulations to the winners, your contact details have been passed on to Fsport. To be in the running make sure you enter for the third event in December. If you're looking for new motorsport tyres or just some advice on moving onto R compound rubber check out www.fsport.com.au or give John a call on 1300 4 KUMHO. Fsport also stocks the range of velo seats and a variety of track related accessories.
Vouchers are valid for 12 months and are for a discount on the purchase of 4 Kumho motorsport tyres from Fsport. Vouchers may be non transferrable and subject to other terms and conditions at the provider's discretion, please contact john @ fsport.com.au (remove the spaces) for further details. The per event prize can't be won more than once by the same person regardless of class entered.
The prize for the championship class winners has been revised but the sponsors overall commitment has increased. Anyone with issues surrounding this matter should PM me to discuss it.
Edited by gregor
Fsport are currently having a mid year sale with significant discounts on a range of tyres, just in time for entrants thinking about making the step up to semis or replacing the ones they already have!
Edited by gregor
Sweet, my 2001 model Formula Rs are nearly past theIr prime.
Round 1 3 laps
Round 2 3 laps
Round 3 Well lets just see how that pans out, LOL.
AWESOME SAU IS AWESOME
AWESOME FSPORT IS AWESOME
AWESOME
Good to see some SAUers taking the lucky door prizes :D
Mark, you forgot to mention....kumho tyres are awesome too ;) I have been running V70A from John at F-sport for a while, and they are a good tyre with consistent performance all the way down in wear.
Horray! I was looking at getting some real Semi's cause these street tyres are giv'n me the Shonks on track days. Hmmmm, now gotta wear down these Pirelli's at the next Texi!
Thanks guys! Maybe my luck is a changing.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
