Hey guys,
I have done a bit of a search and can't find any thing that helps.
I have just had my rb30 crank machined and a crank collar put on. I just test fitted the oil pump gear on the collar and noticed there seems to be a lot more clearance than what I would have expected. I measured a total of 12 thou, Ie 6 though on each flat face. Firstly is that normal? that amount of slop I would have expected to negate the whole purpose of the collar.
Do people shim up there gears? I'm think about getting 2 small peices 4 thou shim and loctite 406'ing it to the crank collar just to tighten it up a little. I noticed tonight that the glue added about 1 thou. so In theory it would bring it down to about 2 thou.
What does every 1 else do?
Lastly when using a standard rb25 pump on a built rb30, do people put say a 2mm washer in the oil relief valve?
regards
Chris
https://www.sau.com.au/forums/topic/368570-crank-collar-clearance-issue/
Chris, that is why I'm a fan of welding the snout up and machining to suit the particular gears you are using. For me, 12thou is way too much slop!
As for the oil pump relief, I'm running a stock RB30E pump on my next engine and I shimmed the relief spring with an approx. 2mm washer.
Hey Mr Bubs, In hind sight I think your onto something and I probably should have gone the welded route.
12 thou makes the oil pump gear rock back and forth like its on a rocking chair. I don't understand why there isn't alot more post's relating to this subject I mean its so damn obvious to me lol
Yeh that point is a good one. However, What does the clearance become when the engine is running and everything has heated up and expanded?
Also another point is the crank doesnt run perfectly centred at xxxx rpm, there is always a certain amount of runout. Too tight on that clearance and it will be just as bad as not having a collar at all. How much runout there is i dont know, But there is no way the snout is always perfectly centred when your at 7000rpm bouncing off the limiter.
But 0.012" is alot, and no doubt it can probably be run abit tighter. But there is no way of knowing until someone who has run tighter can say its been fine and tells you what clearance they actually did run. Or you try it yourself and see what happens.
But I dont think 0.002" is enough. Hopefully someone else with more exp can shed some light here.
If I was going to machine a collar Id probably aim for about 0.006" overall, 0.003" per side. But thats just my own guess. Without knowing expansion and run out its hard to say.
If both pieces are made from the same metal (or if they have the same coefficient of thermal expansion), the clearance will not change if they stay at the same temperature.
how hard did this hit the back pocket? significantly more than collar?
  On 22/06/2011 at 12:17 PM, Don Dada said:
Doesnt the aftermarket crank collars and a std r33/r34 crank measure up the same OD?
I think you might be right but I no longer have the neo Rb25 block to mic it up. I went with the 4thou shim and its still possible a bit tight. I'll have more of a look tonight now that the glue has dried and I can take the sharp edges off the shim.
Not sure on cost as I haven't done mine yet as my forged build is on hold for a while, chuckie should know soon. We had it done to my mates 30 in his GTS4 and that thing cops an absolute beating, 8500rpm limiter launches and burnouts, still going strong.
Realistically, it should add much onto the cost of machining at all. Wouldn't take more than an hour to weld the snout up and if just fitting a collar the snout needs to be machined right down anyway.
On the topic of crank runout.... why would a splined setup ala JZ, not completely destroy itself?
is you mates motor rb26 or rb30?
Whats the 2J setup look like exactly? How many splines and do you know what sort of clearance it runs? No doubt its better then our nissan design. Seems toyota also improves on everything nissan didnt :( Splined from the get go sounds alot better.
Im guessing it probably has ample clearance as well, or maybe their cranks are made of better material and dont flex/runout as much?
25t/30
:thumbsup:
It looks pretty much like an axle end where it goes into the diff.. as for clearance, I have no idea. Shanef was working on a splined setup for RB's but got ripped off by his machinist or something :/
2JZ-GE oil pump..
Hey so it turns out that 4tho shim is still too tight and I can't get the oil pump gear on. which is a pain when I know that if the gear is in position I can push 2x 6 tho feeler gauges under it.
Also Loctite 406 is not a valid option as it is extremely hard to get it to key on and stop the shim from peeling off. Thats If you are quick enough to actualy get the glue on without gluing the shim to your hand first.
My boss suggested using Loctite 680 high strength retaining compound. So I'll let you know I go with that experiment.
At the rate I'm going this motor is going to take about 2 years to get running. Almost give you a run for your money ay Bubba????
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
