Hi all.
No doubt im going to get flamed here but browsing at turbo upgrades atm and came across this one.
Now for an rb20 im guessing its going to be nothing but lag.
Have read lots about the 20G being great on the 20's but how different is the 25G compared to it?
Even with lag of the 25G is the engine itself going to be able to even handle the power produced by it without some sort of engine build/strengthening?
Specs for the turbo are as follows: 600hp rating ,Compressor housing .70arTurbine housing, .63 T3 flange, Water and oil cooled, 360 degree thrust bearing, BOOST UP TO 30 PSI
If your reading 600hp and thinking wtf in an rb20, i can guarantee it will make nowhere near that amount of power.
Anyway, it's late and just want some advice as to whether it's even considerable or just a waste of a topic lol.
Cheers guys
Ryan
https://www.sau.com.au/forums/topic/368576-td06-25g-t67/
Pretty much a waste, and it sounds like you are looking at the wrong supplier for that line of turbo anyway. Make sure you are looking at Kando Dynamic and not some other ebay crap.
The RB20 will need some work to exceed the 20G's potential.. The T67 is a LOT more turbo and will need a lot more to drive it. Really it is only the compressor thats different.. But you get that.
https://www.sau.com.au/forums/topic/368576-td06-25g-t67/#findComment-5876914
I ran a trust/greddy td07 25g with a .76 housing on my evo 7. As mentioned, plenty of lag and lots of work is needed to really bring out the potential.
Also one thing is basically on the kind of setup your after as well. Anyone can do whatever they like; each to their own I say.
https://www.sau.com.au/forums/topic/368576-td06-25g-t67/#findComment-5876925
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
