Hey guys just wondering how my turbo would of died....the turbo was a 3071r new cartridge everything, i had it on the car for three months ran fine then was getting it tuned, then tuner calls me up saying he ran it on the dyno on two runs then my turbo siezed so i ripped the turbo off went back to MTQ to get it inspected they wreckon its oil starvation so i checked my oil lines it was fine no debris, then checked the oil flow so i cranked the engine a few times oil squirted out of the turbo feed line like a fair bit of oil....is there any other possibility it would of siezed the turbo? the water lines are flowing they are not blocked, MTQ kept my siezed cartridge...
Cheers
Chi
https://www.sau.com.au/forums/topic/368578-death-of-turbo/
Cheers
Chi
oil starvation lol standard response
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5876951
There are 2x 20 thou oil feeding pins inside the oil feeding port. when that gets blocked up oil can not pass through, which happened to pretty much all the XF6 turbos we are rebuilding.
Its more less of a design related issue which designers assumed all engine oil is 100% clean, How ever we do have engine filings, carbon deposits and etc that are circulating with the oil. Those oil contaminates comes to rest and collected by the turbo.
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5877374
The XR6 turbo gets contaminates filled up in both filter and the pin. I did have few later model turbos in as well, XR6 turbo repair and high flow jobs are growing substantially this year (Some are due to lack of servicing or bad oil). Also happened to few other GT turbos sent in for repair. Have a close look at the relocation pin (oil feeding pin), it acts like a collection depo for oil contaminates.
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5877507
Lol, an inline filter feeding the turbo? What a stupid idea. People who drive cars like Ford XR6T, VW golf GTI and other turbo charged cars sometimes forget they are driving a turbo charged car and do not service them. I know a guy with a VW turbo who does his services every 20000km. I tell him you have a turbo there which does not like dirty oil. His response? "That just happens on shitty skylines". Lol.
People also need to remember that there are manufacturing faults. Its not quite fair if Garrett or any other manufacturer just blames the end user. Sometimes shit can go wrong because of them. I bought a GT3582R turbo off a guy. Turbo done 200km on his car(all dyno work). When I got the turbo home, rear wheel was destroyed. It was replaced under warranty but I got a refund from him anyway. They tried to blame him but he always ran a filter, his engine is still healthy etc. In the end there are manufacturing defects which could happen. Some companies need to get off their high horse and put their selves in our positions.
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5877562
True statement made a couple of posts above but one would immediately assume that when with the way its setup, a thin hose for feed and a relatively larger hose for return, that if any junk and desposits were going to contaminate and block the lines, the thinner line would go first. But as a general rule, it is always best to look at all your lines to ensure what is and what isn't going on.
Before you strap on another turbo you might want to consider getting an oil analysis done. It will tell you if you have excess wear and rubbish in the oil. You'll also want to drain and clean everything out and ensure all the old shit is out of the car just to be sure. Run some oil flush through it followed by some cheaper oil then put your good stuff in there after letting it drain. Its off the road so let it drain really well.
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5877714
High exhaust tem can burn turbine wheels tips which are only 20thou thick. I've had few of those too. the bearings are cooled by oil and water so the bearing housing it self is not affected unless coolant is not present. So did you connect water to the turbo?
If oil drain is blocked or having issues drain oil, the turbo would leak oil out of both ends, how ever that doesn't stops the turbo from spinning, might seiz after a long period of time.
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5878269
Sounds like a good idea to me. It will take a lot more crud to block a filter than a flow restriction orifice.
They may be right. IIRC the Golf GTI's are a low boost, low stress motor. Combine that with extended drain interval fully synthetic oil, 20,000kms shouldnt be a problem.
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5878315
The way my mate drives his car is a joke. He thrashes it beyond thrashing and I tell him why didn't you just buy a second hand one. He bought it. Brand new, and treats it like shit.
https://www.sau.com.au/forums/topic/368578-death-of-turbo/#findComment-5878834
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
