Hi Guys,
Im thinking of getting Coilovers for my R34 GTT and not sure which ones to buy. Ive looked at BC Coilovers and Pedders. Whats the difference? Who do you guys recommend to get them fitted im in melbourne? What am i looking at for the right coilovers, i just want them for a comfortable ride. Also what are some prices am i looking at for the coilovers and fitting. any advice is appreciated.
cheers
Hi Guys,
cheers
ARE THESE ANY GOOD? THANKS GUYS.
http://www.justjap.com/store/product.php?productid=18623&cat=&page=8
Im no expert but the differences you will be looking at is the spring rates and how stiff you want them. Most jap ones are stiffer for drifting and ect.
The pedders one are more suited to australian roads i have been told andthey do a kit for a 34gtt i think they were saying 1600ish
Hey mate I've got a set of apexi wd coilovers direct fit for a gtt for sale if your interested. There height adjustable only and very comfortable, not to stiff at all for our roads. Looking for $700. Done approx 20 thousand km and in very good condition. Pm me if your interested and Ill send through some photos.
My local Pedders tell me that if you get their coilovers fitted by them and you don't like them they will fully refund your cash no questions asked.Go see you local dealer
Steve
Hi Guys,
cheers
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
