So I was exiting out of my mate’s apartment basement car park at Wolli Creek the other day, it has a really steep (30 degree?) and tightly curved sloped driveway which also happened to have a little pool of water at the bottom flat portion of the drive. Now my mate in his stock Lexus IS200 went up this drive as easy as a snake sliding up a fence. Following him, I got like 1-2 car lengths up the drive and couldn’t go further – so much excessive wheelspin and could smell the tyre burning (thought it was the clutch at first).. 3-4 attempts and no luck. I even pulled up the handbrake on the slope, gave it some revs, then dumped the clutch normally, while putting the handbrake down, and still wheelspin at 3,4,5,6k rpms…
Got my mate and another guy to sit in the backseat to get better traction and we only JUST managed to crawl up in centimetres, wheelspinning as before, after the second traction we went up the slope easily, just at the bottom curved bit which was also wet.. My R34GTT has quite firm rear Cusco adjustable coilovers and the front end is a noticeable bit lower than the rear – same Cuscos in front.
My other mate with his stock Nissan Tiida who lives on the block never had this issue before.. So you can imagine them both ribbing me about how my high performance turbo car couldn’t get up that ridiculous driveway when their shopping trolley rides slide up and down like pros.
Anyone got any suggestions as to whats wrong with me not getting traction – hard suspension, front bit lower than rear?? – my tyres are really good – 235/18s, my traction control dosen’t work though, the light in dash is always off.
Maybe I was revving too much, but still? The lexus is a manual and I do know how to drive haha so thats not the issue, I even thought my car is pulling too much torque at low revs causing the wheelspin, but then a lot of you guys are pulling waaay bigger numbers than me and I've never heard of anyone bring up an issue like this..
Your skyline has way more torque than those other cars.
For a steep hill/driveway ( AND WET!!! ) you would need to ride the clutch quite a bit or like you did handbrake start, but dont rev it so high, creep it.
More power = more wheelspin, keep the revs down low, 1-2k range.
Edited by jay-rod
Dunno mate, bought it like that, that was the only thing in my car that dosent work, thats why its pretty dangerous in the wet, even driving it normally, wheelspins very easily, it does have the 2nd traction control butterfly in the intake though, I think either the unit is fuct or the fuse is blown..Anyways I am pulling a kinda healthy 545Nm torque on the stock turbo, tuned to awesomeness by DVS Jez on SAU
My question is - what happened to your traction control system? Anytime I've been in that situation, traction control would kick in and make it fine.
As far as i know Traction control does not stop both tyres from spinning after they have started.
It only stop loss of traction from the beggning.
So if he floored it, traction control can only do so much.
But yes no TCS would not help either :P
Edited by jay-rod
I did strongly think its my stiff suspension, but my tuner said my suspension is beautiful compared to the really hard race-type suspension that he is used to... Could be that my low rpm torque is a bit much for that slippery steep slope..?? The IS200 also a rear wheel drive, didnt have any issue at all, and niether my other mates Tiida - which would have more traction as its a front-wheel drive with the heavy engine in front?
I always thought the R34 has a good front-rear weight distribution although not as good as a mid-engine mounted car, so thought how the hell is the weight distribution causing this issue or is it something else..
i just think you gave it to much throttle.
Have you checked all your fuses? The traction control not working could simply be the previous owner taking the fuse out or it could have blown?
*Edit - If problem persists buy a GTR :happy:
Edited by r32line
Anyone else had this problem? Nobody thinks its my stiff suspension and heavy engine in the front = less grip? I must say its very easy to wheelspin in this car, even in the dry straight roads, when coming on boost suddenly..
Doesn't the traction control system in R34s cut power by closing the throttle body? If this is the case might be able to get up the driveway if you use more delicate throttle control... or no throttle at all
To be honest, I'm thinking either diff or tyres (or a combination of the two). You definitely won't be going anywhere if you are single spinning... I remember trying to drive my cousin's Commodore onto my lawn and I got stuck because all it could do was peg leg!
Stiff springs on the rear end is probably a contributing factor but not the cause
Yeah sounds like you're just giving it too much. Only time I ever had similar in my old 33 was when I had bald tyres, with good tyres you should be able to just take it easy and slip the clutch a little.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
