Hi everybody,
I've got a few sets of parts I'd like to sell off.
Genuine quality Tomei parts.
These things are truly WORKS OF ART.
PLEASE PM ME IF YOU'RE INTERESTED.
Save time and contact me directly.
Location: Brisbane 4157 - Can easily post this stuff all over Australia.
Tomei Expreme Stainless Steel Exhaust Manifold Kit R32/R33/R34 GTR RB26DETT
Price: $1075 including postage Australia wide bar TAS.
Extra for insurance and registered post.
HiOctaneDirect - $1150 + Shipping
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=22_103&products_id=719
JustJap
$1400 + Shipping
http://justjap.com/store/product.php?productid=17907
Condition: Brand new
Includes: 2 Expreme Manifolds, 2 Rolls of heatwrap, Metal Ties, Instruction Manual, Gaskets, Sticker, Gasket Paste
Pictures:
Tomei Expreme Dump Pipe Turbo Outlets R32/R33 GTR RB26DETT
Price: $850 including postage Australia wide bar TAS.
Justjap - $1200 + postage
http://justjap.com/store/product.php?productid=16976
Pictures:
BRAND NEW SEALED R32 R33 GTR RB26 Tomei Poncams Type B
Price: $850 plus postage
Condition: Brand New
In/Ex Tomei Poncams Type B
260 Degree and 9.15mm Lift
RB26DETT
R32 or R33 GTR
Pictures:
Item:
TOMEI Complete Gasket Set.
1.8mm, 88.0mm Bore
incl: metal head gasket, metal intake manifold gasket, metal exhaust manifold,
metal throttle gaskets, oil gallery orifice.
Condition:
BRAND NEW - Sealed Packet
Price:
$500 + Postage and Handling
$450 ONO!
Pics:
  • Like 1
Price Change
Tomei Expreme Manifold - $1000 Delivered
Tomei Expreme Dump Pipes - $825 Delivered
Tomei Poncams - $850 + Postage
Tomei Gasket - $450 + Postage
Tomei Cam Gears - $430 including express post Australia wide.
http://www.skylinesaustralia.com/forums/topic/369701-brand-new-tomei-inex-cam-gears-pulley-rb-202526/page__gopid__5896580#entry5896580
please read forum rules, no excessive bumping.
thanks.
No worries. Noted.
im interested in the pon cams and extreme dumps, are the dumps a direct fit for r32 (small oxygen sensor) without modification?
Scott
Have sent you a PM :)
BUMP.
Can work something out for a few items :)
CAM GEARS $400!
BUMP
Will be in Sydney next week at the WTAC.
Will require a deposit before I bring something down though.
Cheers
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
