Installed a 1.5 way in my R33 GTS-T recently and she's very, very clunky. I know they are supposed to be when turning corners at low speed, but this is a very violent kind of clunking...talking, like someone hitting the underside of the car with a hammer. I can feel it through my seat! I did the break in procedure, and it did feel better after that...it stopped clunking when turning with deceleration / throttle off...but still does it plenty with throttle on, ala turning at an intersection or stop sign. Strangely, if you have enough throttle on when taking the corner (put your foot into it), rather than clunking it will just tyre chirp/pivot which is much more pleasant.
I drained out the oil today and put in fresh oil with some anti chatter / friction modifier...took it for a short drive and that seems to have helped a bit. But I am hoping it will go away in time. I don't mind some minor clunking, it's to be expected from a diff designed for racing...but this heavy shit has to go.
What are other peoples experiences with their KAAZ diff? The grip of this thing is fantastic. Ordinarily, driving in a straight line in the wet with second gear coming onto boost would be straight into a fishtail...this diff just held it's course on the straight and narrow. So can't complain about it's functionality, just the clunkiness on turns that is driving me nuts. Sounds like a friggen driveshaft is about to snap :/
https://www.sau.com.au/forums/topic/368611-whos-running-a-kaaz/
I have a 2way in my 32, have had in there for 6yrs i love it. Was very clunky at first, first oil change used ls140 and friction modifier. Hardly clunked after that.
What oil did you use?
Did you break in the diff by doing figure of 8s?
Also when you installed the diff centre, was it a backyard job? if so the back lash might be off.
I had very similar problems with my old 180SX which I bought, it would violent clunk and shudder as you have described, turns out the back lash wasn't set properly by the old owner.
Yeah I did figure 8s...that got rid of the clunking when turning under deceleration. Didn't do much for acceleration though. Had it installed by professionals...backlash seems to be okay, but will get it checked by them. Should the backlash affect it much when it's turning under load though? I would have thought throttle on/off would produce a backlash clunk, but not while turning with throttle constantly on?
personally what you describe sounds perfectly normal to me. I've owned probably close to 10 cars with various jap LSDs in them and most are like that. clunk so bad you think the arse will fall out of it one day. that's why they are supposedly for competition use. they are fairly savage in a road car.
Birds, its fairly normal for it too clunk that harsh at first. It might take a little while longer for it to calm down, seeing as it is a new diff. If the backlash was wrong the unit wouldn't last that long. You didn't use 80/90 when you changed the oil did you?
I changed it for LS90 (monograde) and used about 100ml of Dana friction modifier...drive home tonight wasn't as bad, seems to take a bit more steering angle to start the clunking. I've done about 300km since installing...maybe I need to be more patient with it. Really wish I could just take someone with KAAZ experience for a drive and have them say "that's totally normal, you won't snap a drive shaft" lol. Need that reassurance cause the whole reason I upgraded my diff was to get rid of ye olde clunking standard diff haha...exchanged one problem for another! Don't wanna put too much friction modifier in as it supposedly wears out the clutch plates faster and reduces the effectiveness of the lock.
KAAZ do say their product is only designed for race use so I guess that's the warning everyone should heed,but doesn't. Will have to hit up some events to make it worthwhile putting up with it in a road car!
KAAZ was cheaper. I originally wanted a Nismo but $1600+ fk that. Heard good things about the KAAZ and it's serviceable worldwide,including Australia, so rebuilding is easy.
Nismo was $1600+? :O
Did you know Link have specials on ATM as they are getting rid of all their Nismo stock?
I got a Nismo front diff for my GTR for the same price it was delivered ex-japan :)
It shouldn't be "too" clunky though. Perhaps a minor adjustment to the backlash now it's got a few KM's on it. Few people have had that issue in the past.
I'm talking Pro TT in a 1.5 configuration (2 way I've found to be cheaper across brands)...I did see them for $1300 on eBay at one point (talking 12-18 months ago), but by the time I got around to actually wanting one, the seller had no stock left. Now the eBay price is $1600+ last I checked. Biggest appeal for the Nismo was the half shafts that came with it...that and everyone raves about them. Had no idea about Link...however, I did buy this KAAZ about 6 months ago, only just got round to installing.
I got the KAAZ for $1150 delivered to my door IIRC. Couldn't pass that up for a 1.5 way that everyone raves about as much as the Nismo. Driving again in the wet tonight, I can see why. You can hear your wheels spinning, yet you continue to pick up speed. Now if I can just get it to drop most of the clunking, it'll be the perfect diff...
Might have to look closer at the backlash then. There was only a little play when I had it up on a hoist today...only a few degrees of tail shaft revolution...hardly enough to cause anything serious I would think.
No idea where my crown and pinion is from lol, I stole it from another R200 with ABS. 4.08 ratio :/
http://www.nengun.com/nismo/gt-lsd-tt-pro
$1383 delivered. I wonder how these would go with noise etc vs the KAAZ.
Will be watching this thread with interest
Don't you have to be a trade member to get stuff off them Ash?
Where'd you get that price from? I logged in and it quoted me about $300 worth of shipping...
Total AU $1,558.22
Are Nismos not just rebranded US lsds including Kaaz?
Use Motul 75W 140 special diff oil for lsd(which I believe is the same as sold by Nismo).
So I've heard...thanks for the recommendation, might try it next oil change if things haven't quietened down by then.
$1500+ once you get stung with tax :thumbsup:
As above, and yeah, good point on the tax.
I will keep this thread updated with my progress. After Googling the issue, seems it's a very common thing to have, so I'd say what I'm experiencing is, as Beer Baron said, quite normal for a brand new Jap diff.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
