Looking for interest in my A31 I recently purchased, only selling as a particular car has become available to me...
Orange A31 ( was bangers old car ENEMIE )
Things it has -
Shit to drop in SR20
5 Stud kit ( R33 gear, missing front calipers )
Uras front bar, Wonder skirts, Wonder rear bar, mesh grille
Adjustable arms
Steering rack spacer
Rear coilovers (JIC Silvers)
Stock front struts
Rear seats and door cards, near complete interior ( needs front seats)
walbro fuel pump
3" zaust
Things it needs -
Besides the obvious motor and box
Diff
front seats
master cylinder
few other bits and pieces
I have stock front and rear bars
spare doors
spare guards
spare bonnet
spare boot.
Comes with the car.
I paid 2500.00 for it as is, no suagr coating bodykit needs work but its not to bad, rear damage has been 90% fixed and wont be a biggie to finish. Rest of the car is straight, glass is perfect (no tint)
I had the 5 stud kit put on so price will reflect this.
3500.00 for it all, roll away on stockies. Or can reduce price minus the 5 stud kit.
0430-124-417
https://www.sau.com.au/forums/topic/368613-fs-a31-roller/
  • 7 months later...
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
