block all the intake piping with glad wrap or some form of plastic film, remove the airflow meter and dont get the coilpacks wet
dont spray water all over the shop in the engine bay, there is no need
use a degreaser and just wipe it quickly
ie dont goto your car wash and bomb the engine bay with a pressure gun
thats a no no
degreaser and some wipes is all you need
you can HP the engine bay, taking the above precautions but i must admit... i'm not a big fan.
go to bunnings, get a product called 'Simple Green' - put it in a little pump-pack type spray bottle (check the dilution notes) and just mist around the engine bay and wipe down.
Otherwise i would do the same with Final Inspection's GPC (General Purpose Cleaner)
Different materials (plastics/metal/rubber) may require different products as well, but the above mentioned ones would be fine to start with for a general clean
thats a no no
I saw someone at a self serve carwash take a high pressure hose onto his ford falcon engine bay. After he was satisfied with the hose down, he went to start the car which stalled 3-4 times before it limped away >_<
I've used a high pressure host before a few times, never had a problem.
Just don't spray @ ignitor/coil packs, and the airbox/pod/AFM area. Spray something to "presoak" like some warm soapy water, then have at it. Basically you want to 'shoot' like if using a gun/pistol - spraying the water downwards so it doesn't spray/fly everywhere.
As others have said - do NOT just go gung-ho and spray anything and everything. Just take your time and it can be done
Don't use the car was pressure hoses though, the water there is generally dirty. I've always done it with a Karcher @ home or similar and taken my time.
Once you've done that and gotten the bulk off, then just use a 'mit' or something with soapy water to get in and around everything and remove built up grime.
yeah pressure washing is fine, do this first.
But for real results you have to get in there with a few cans of degreaser and a rag and scrub at the build up..then pressure wash again, just dont hold the gun to close.. soak it with truck wash or degreaser first and it will be fine
dont expect instant results..do it once, twice three times and then it will start to look great ;)
i didnt wash my engine bay at all , i decided to keep water away from electrics !!!!!!!!!
the other option is to remove engine parts seperately yes.gifand hand polish with soapy water and use metal polish for stubborn parts ,
its a long process , if you wanna get serious ??????
@ nissan gtr yes i am thinking of doing that coz after washing my engine bay it doesnt look any difference. i jus wanted some advice regarding pulling out the parts. like what should i do after undoing the rocker cover do i need to cover the engine with some sort of things to prevent dust etc help me i have no clue
of course you should cover it..just an old clean shirt or something will do
did you soak your engine in degreaser before you washed it..?
just get a few of those 2$ cans from supercheap and totally soak it especially the greasy bits then drive to the car wash and hose it..you may need to do it a few times though for good results..
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
    • Barrels don't need to be shiny clean. But they are certainly nicer when they are not polluted with years of brake dust, and worse the rotting corpses of the last 17 balance weight sticky pads scattered all around.
    • Yeah, type a special character like ^ or | to initiate the equivalent of the "at"ing for thread links. Although, it might not get any easier to manage. Imagine 30 or 40 threads that kinda match what you want, and the one you want is lost after a long list of useless ones. The magic keyword version I proposed would be a manual effort to set up each case. More of a directed effort from the greybeards to facilitate exposure of useful content. I'm not against the auto complete stuff being considered - maybe por que no los dos? (And where I said "triggered automatically" in my OP, I meant "triggered accidentally". Of course I want it to be automatic!!)
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
