Time to move some stuff on since car is either sold or change of plans
Everything is new unless stated, most bits are hard race, some JDM brands
but because they were bought over the years for various cars its hard to
remember exactly.
Alloy Subframe collars. Fits all Silvia's and skylines $110 shipped (Jap brand unknown)
4 Slotted 4 non slotted for lower
Pineapples for Squat/drift. Fits all Silvia's, R32, R33 and R34 (Aus made) $55 shipped
Similar to most 4 pce kits except red
Silvia HardRace Front Tie rods and tie rod ends with lower RCA (spherical) 150 shipped
Will also fit R33/34 rear tie rods/hicas
silvia/R32 GTS Section RCA Ball Joints (front) $100
S13 Ladder Bar brace $199
S13 Carbon Fibre rear strut brace approx 35mm dia (used) $140 JDM
Hard Race rear RCA Ball Joints Silvia/skyline $175
B pillar brace, fits most nissan's. Some may need an extra hole drilled in the mounting plate $100
R32/S13 Adjustable rear camber upper Arms $145 Shipped
Rear traction arms skyline/silvia $100 Shipped
R32 GTR Forged castor/tension rods with CRMO ends $180 shipped (jap, possibly kts as they are like the ones here)
R32 R33 GTR Cusco Tension Rod brace $145 Shipped
The Silvia and R32 GTS parts are all crome moly as they were track only, I havent had these
cars for years so not real sure why I still have some parts. R32 GTR parts are mainly sperical
bearing that I dont want to use since it will exceed my current NVH limit
Shipping is via express post except some of the larger items like money bar, strut brace and ladder bar which
will go via registered, pm me with your post code for a quote or pick up in sydney
Pic as above, pretty much the same shit but the end plates look slightly different.
More stuff, as much as I would love to own another track S13 prob wont happen any time soon.
S13 Ikeya LCA's $490. Used, awsome condition, probably only 2k klms on them. Been in shed for atleast 3 years gathering dust.
Never ripple strip bashed, pirrow bralls in excellent condition. All ferruls, castle nuts included
Silvia hard race Tie rod end RCA's, pillow ball. $75 Shipped NEW. Pic as above but without inner tie rods.
S13 ultra racing Inner fender braces. Didnt end up using as extending the cage made them redundant. new $120 shipped
S13 ultra racing lower brace, bolts from the tension rods to the back of the LCA's, never got around to using it before selling the car $189
Also R32 GTR Ohlins C Ring coil overs, came with the car. Unsure of klms/spring rates but has been in daily driver. $550 currently still in
car so can take you for a run. Suit street, probably very mild track work. Inverted rear, no shock adjustment (not really needed)
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
