i have a new 3 puck ceramic clutch and the friction point moves
in the morning i step down on it there is a hissing noise as there something is lossing pressure and the friction is very low and easily stalls if you are not careful then after awhile of driving the friction point moves up and still have a tiny friction point , within 2 cm its between 9000rm and stalling the car so anyone know whats wrong with it
any help would be great thanks
https://www.sau.com.au/forums/topic/36865-clutch-hissing-noise/
Who installed the clutch? Does it make the hissing sound if you pump the clutch in neutral? Might be that it wasn't bled properly. You can adjust the friction point to suit driving needs...sounds like yours is too low...had a similar problem with my Daiken Exedy installed a couple of months ago and had it re-adjusted and the system re-bled problem fixed and no more "hiss" noise..
Hey J-13 mine was making that hissing sound (i thought it was the thrust race) but as fate would have it with diy installs it only happend when the car was cold........When it gets warm though its allright it just took a bit of soft driving to bed it in i think.....say a hour or two drive in moder8 traffic conditions.GTR-MAGEDDONIT may be right your point of grab adjustment could be the answer.... Hope this helps....Another question can hydraulic clutches be adjusted like cable clutches?
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
