Step 1 - decide on desired power outputs any said clutch would be expected to handle
Step 2 - consider use of vehicle (track/drag/street)
Step 3 - pm the clutch hookup guru of these forums.
Hint: anagram of Mazda.
Step 5: high rpm launches at next track day
https://www.sau.com.au/forums/topic/368669-help-please/#findComment-5878505
it would probably help if you put up your power levels, and use of the car.
i've got a Jim Berry 'Montyzilla' in my 32 GTR and it handles 350+kw and is still soft on the pedal and has good progressive engagement (for car park speeds)
i spoke with Jim and from what he told me the STD flywheel is better than the lightened ones because it doesnt make engagement so snappy, has something to do with the weight and the rotational force?
for a street car you probably want a sprung centre clutch too, so you're not smashing through the gears so hard.
from my experiences i've had the extreme clutch kit, 6 puk with stronger pressure plate and lightened flywheel.
had it for around 2 years at 210kw and had it repadded, lasted about another year and 1 trackday and it was slipping. wasnt happy then i sent it to Jim Berry and he repadded it, changed the pressure plate fingers and i went to a STD flywheel and its the best its ever been. had it for just under a year and 1 track day use.
https://www.sau.com.au/forums/topic/368669-help-please/#findComment-5878805
Pete you should give the NPC twin plate some consideration awesome clutches and good value straight off the shelf it will hold 400 is and can be talor made
Mark Jacobson runs one in his 1000hp drag gtr and in the event you need a rebuild later will be hundreds of dollars cheaper than a nismo
https://www.sau.com.au/forums/topic/368669-help-please/#findComment-5878897
I don't mind spending money on quality parts especially when they have such a solid reputation as the nismo clutch does.
This! /thread
I have one, f**king fantastic, best clutch I've ever used and takes a whooooole lot of shit. Easy as piss to drive too
Is that 2k with the lightened flywheel? even so that's good value for a twin plate let alone anything nismo
https://www.sau.com.au/forums/topic/368669-help-please/#findComment-5879615
This! /thread
stop being a brand whore :P:wave:
EDIT
*cough* i can get NPC cheaper support Australian manufacturer's
https://www.sau.com.au/forums/topic/368669-help-please/#findComment-5879625
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
