At the end of the day, with clutches i think you get what you pay for.
don't pick the cheapest, mass produced clutch on the market because you'll find once your pushing 300+kw through it, its going to start to wear and have a short life.
you don't need to be a brand whore, but if you talk to genuine people in the business that know their stuff and arent just trying to make a sale. you'll soon find out what is good and what isnt.
simple little things like pivot point at which the clutch engages has a big effect on pedal feel.
i'd say you're going to be up for $1500-$2000 for a full clutch kit which will be reliable and hold a fair amount of power.
trust me, from my experience. do it right once, and not have to change or rebuild it every 12-18 months
if you're after a single plate, i reccomend talking to Jim Berry. but if you're dying for a twin plate. probably go for a Nismo
i went for single plate because it is cheaper to rebuild, whereas nismo can be costly for a rebuild kit.
but sometimes you never know how long a clutch will last. if the material is good and all your pads are even then it should last a long time. but if they aren't all equal width like mine were when i had it rebuilt by someone other than Jim Berry (not mentioning names) it didnt last and because of the uneven wear the engagement wasnt very good at all, it would slip because the load wasnt evenly spread over all pads.
Other than the power you're producing and the way you drive the thing, you also have to consider how much street use vs track use the car will get.
The only thing you've told us is that it's for a 34GTR.
Answer the above questions and the guys will be in a better position to properly reply.
Last thing we want on here is Andrew and Steve getting into a pissing competition :P
Andrews will go further he's taller ;)
I am the most bang for a buck guy you will meet. I have no experience with the NPC, but numerous examples of a certain other well advertised local clutch which just does not suit the applications it applies to. Trust me, spend once, spend less. You want to argue with 450+ rwkw on a mainline with slicks and semi slicks on the track, numerous 9000rpm launches, come see me, got the experience. When it comes to this, I don't even think of the clutch, simply, it works. Or you could spend half the money, at least twice, and worry about the clutch. Simple really. And yes, I am taller thumbsup.gif Steve you joker you action-smiley-069.gif
;) NPC's main clutch guy used to work at excedy he has run on the boards and doesn't talk rubbish either
i tell him the application and he tells me if he can build it
this is his HD skyline clutch
The pressure plate I use is a standard Exedy cover that is pulled down and fitted with the same diapghragm spring nismo uses in some of their pressure plates. I then modify the Exedy pressure
plate to suit a 5 puk sprung center disc that I make using a 4.2 ltr patrol clutch plate.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
