As the title states I cracked a ring land on #5 and scratched the bore. I have heard people say that you can just go over it with emery cloth and call it good. I know this will work in some cases, but I also know it has its limits. I dont really have any way of measuring the depth of the scratches but mostly it is just very light and I cant even feel it. There are 2 spots that I can feel although they are also very light just barely enough to feel, probably only .003" deep and about the same width at the worst part.
I know for a high hp engine any scratch at all is probably a no-go but my plan is just build it back to stock engine specs and stock boost for now. will a new piston and rings and a bit of emery cloth do the trick or do I need machine work. I know it is probably impossible to tell for sure without being here and seeing it first hand but if you have any expierence with this, please let me know what worked for you. cheers
If you are deadset on fixing it yourself, Atleast get yourself a flex hone and clean the bore up with that rather then emery cloth. It will atleast keep the bore closer to round then leaving a flat spot where you would go over the scratches with emery cloth. While you are at it, do all the bores with that and chuck new rings in. If the scratches dont go after a hone, then it needs to be bored oversize.
Get a hone done and see how it looks, don't take to it with sandpaper, if the marks still there after a hone you can go with a bore and and lager pistons.
Just called my personal mechanic back in the states (aka My father) and he gave me the same advice. So it sounds like a hone is what I'm doing! Thanks for the advice and the second opinion.
Dude, I'd get a Hone, acid dip, and deck done.
Would cost you around $250.
It really is worth the trouble and expense, as you won't have any issues then.
Set of standard rings would be about $100, and change the bearings while you are at it. Thats another $100.
You'll need a new head gasket - $about $50 if you find the right place.
Totalling around $500
If you skimp for a lousy $100, here and there, you'll be pulling the engine out and down again, wasting days of time, extra head gaskets, seals etc. Trust me, been there done that. Just do it the right way first up, because saving $100 isn't worth the hassle of pulling the motor out again.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
