Nissan Datsun Skyline MR30 sedan, series 1, 1983
Runs well, 254000kms, 3 speed auto
Seats have been replaced, reco distributor, air con condensor replaced and re-gassed (working well), new ignition coil, Ti steering wheel, nice chrome 280Z Tbar selector, good tyres (195/65R14).
Bodywork is fair, some repairs done, some scratches, rust repaired in passenger door.
Windscreen has a chip that was repaired (passed RWC last time with the repair).
Registration expires 14 July, sold without RWC
Price: $800.
Buyer has option of purchasing a good collection of spares including:
L24 engine (~130000kms); EFI manifold and injectors; 3 speed auto box; 4 speed auto box and VL tailshaft; extractors; front struts complete with standard springs, disks and calipers; low front springs; starter motor; alternator; aircon compressor; radiator (manual); trans cooler; water pump; speedo cable; and a collection of EFI sensors and relays.
Price:$800 with the car. (Will re-advertise spares later if buyer doesn't want them, will not separate at this stage).
Contact: via PM
Photos: (to follow)
  • 1 month later...
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
