was that using a 26 intake ??
I was trying to avoid spacing the subframe down so as not to effect my roll centre
I can't see how you would fit a 26/30 combo into an r32 of any kind unless you used an rb26 style front-facing plenum (or why you'd want to run anything but the front-facing plenum).
With the GTRs, the main issue that affects the engine mounts is having enough clearance between the big alloy sump and the power steering lines.
I imagine that in rear wheel drive configuration, the fact that your sump is a bit of tin could make it possible to mod the sump to allow more X-member clearance, and mod the mounts to drop the motor.
In terms of the timing belt cover clearance issue, apparently there is some way of fitting the rb25 cam covers and timing belt cover to the rb26 head etc, that gives more clearance.
Once that's done, there's the issue of the twin turbo turbo collector pipe. I got a bit of clearance by grinding off the alloy mounting boss, but still needed to run 20mm spacers in my bonnet hinges.
Edited by dorifticon
https://www.sau.com.au/forums/topic/368722-2630-into-gtst/#findComment-5880960
or just custom make the mounts so the sump is as low as it can sit on the steering colum then work out if you still need to cut the bonnet.
my Rb2630 went into the s14 with no bonnet/ hinges mods. it has a dry sump on it and the sump is 4mm off hitting the steering colum,
and we had to solid mount the motor to ensure no twisting..
Edited by BMYHOE
https://www.sau.com.au/forums/topic/368722-2630-into-gtst/#findComment-5887828
Thanks but i have a gtr bonnet already. Im going to look at running fd mazda rx7 mounts as they lower the engine
Just use the R32GTSt (RB20DET) engine mounts and redrill the holes lower as per the pdf guide, that should get rid of most of the clearance issues and all that might need attention is the "twinturbo" pipe.
https://www.sau.com.au/forums/topic/368722-2630-into-gtst/#findComment-5887917
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
