mine stalls if i pull the plug??? is that normal.. i put the idle down to 1000rpm today and it stalls like a bitch at every traffic light.. but is alright after a while of sitting there.. i also listened VERY closley and could hear a air leak some where. im pretty sure now that this is my problem just gotta find the air leak..
  • Replies 41
Just to throw more fuel on the fire....
My car does this (did this). I changed the fuel pump on the weekend and found the severity of the surging (if you can call it that) was reduced significantly, most mornings i can't even feel it anymore.
Which leads me to think it may have something to do with the fuel pump voltage controller, which drops the voltage to the pump at idle and cruise to quiet it down and improve it's life span. You may find it's switching between high and low pressure or something when the car is cold and trying to pump more fuel in?
I don't really know it's this, just theorising based on my experience.
I know this is for an RB20, but I had some very weird behaviour in my 33... hunting, lack of power, etc... then stopped the hunting, just ran shite... turned out to be the coolant temp sensor. I mention this because we (the mechanics and I) thought it was the o2 sensor at first... then the AFM.
To test this, go for a drive, get everything nice and warm, then yank the cable off the temp sensor. If the engine doesn't go nuts and rev and carry on, then it's that. And if it does, just pop it back on, all good.
Free engine self-diagnosis, gotta love it. :)
Okay... erm... hard to explain without a picture, but standing in front of the engine bay, look down towards the oil filter... in your way will be a 2" sized pipe, with a sensor situated about 4 inches out from the side of the block, on top of the pipe.
Hope this helps. If it doesn't, I'll find a photo.
edit: Oh, and the pipe will be leading into/away from the radiator.
OK... I found one of the problems.... The serging of idle is being caused by the ACC Valve. Located at the rear of the plenium chamber. However all said and done... try and find one... I have disconnected it completelly and the car is not serging...
However the stalling is still happening. I thought it may be the fuel pump so i have re-wired the fuel pump to be on high presure all the time. I alos have a fuel pressure reg with a gauge so i can see the preasure is not dropping when this happens. As mentioned earlier in the piece i replace the 02 sensor. Today i did some spark plugs.
Now the Acc valve seems to be a solinoid... It is a closed circuit and when voltage is applied there is not movement in the valve... My question is how does it work and whats its purpose exactlly??? The operation of the valve is funny, you can push the tip in about 10mm and it will spring back, this corosponds with another tip on the plenium... It does not send signal as i said before its closed circuit... So im assuming its a soliniod... but it does not puch out so im beet... Any ideas...
Also im pretty sure the stalling and carrying on is cause by a faulty sensor of some sort.
Also about the colant temp sensor, if you disconnect this sensor the car should return to a high idle, this is caused by the computer going into limp mode. Has nothing to do with wether its faulty or not....
I have replaced 2 before with no changes (this info is from the guys who replaced it)... On the bright side the colent temp sensor on the rb20 is the same as a nissan Maxima so the cost of getting one new is only $50 from Nissan...
Anyway guys, i think its time to through the whole thing....
I have spend over 15g's on this car and still its one prob after another...
thats what i did.. but i screwed mine to 1500.. wow.. sitting in traffic and couldnt hear much (3.5in exhaust and 1 muffler) got too annoying.. col-gtsx - when i replace my motor ill lend you my spare idle control valve and you can try it. not sure when it will be but ill let you know and if you still got problems well give it a go. another thing to try is look at EVERY VACCUME line in your engine bay!!! try fuel filter if it hasnt been replaced for a while.. your fuel reg could be stuffed (you said you have an adj one.. have you taken the vac line off the std one and just let the fuel run through it? could have a leak some where) hate to say it but my head gasket is causing my idle to screw up.. mite be worth a check. the other nite i got the contact cleaner out and cleaned some of my coil packs also noticed on the wires going to the coil packs (the loom thing) that a lot of the wires didnt look the best.. looks as if they were burnt etc.. it would be a nitemare but mite fix it if you replace the wires (:D) haev a look at the back of the plenum but under it and you will see another regulator type device on the fuel rail whats this for??? have a look at the vac line going to that is it cracked i changed mine and tried taking the one that was on there off.. took a while cause it was the original one.. there are just some things i was thinking about tonight. hope it helps.. if anything can/does at all..
Yes.... the cold start item will play up when the engine has passed about 150k's but has no real direct affect with the operation.... cant stall the car just makes it a bit jerky on the pedal when cold... but this cant be helped anyway...
The AAC valve is certainlly the cause.... I am replacing it next week with a gen part.... but ill do the collant temp sensor as well as this after noon i droped the endless chain on it and broke the %$#ing thing....
My issue sound very similar to this one
http://www.skylinesaustralia.com/forums/sh...4564#post814564
abve i talked about the timing changing all of the place and this can cause it.... Well in the post above another guy has measured the timing when the fault occurs with his motor and its all over the place....
Only 3 things control the timing...
1> CAS
2> ECU
3> AAC (in directlly thro ECU)
Ummmmmm ideas.... Anyone got a spare CAS for a silver top i can borrow for a week????
OK... problem gone for like over a week now...
Then as im starting to be a little happy about it... this arvo it did it again.
Revs up and down... get out of the car, unpluged the AAC valve and the car returns to normal... However with this unplugged it has a tendancey to stall un-expectlly... So i got to cross a major road in Brisbane to limp it home and what happens.... Yep you guessed it...
Then to make things even worse. The Police were sitting waiting for me to push it out of the way only to give me a hard time.... It took them 20 minutes of checking the car inside out to find that its perfectlly legal.... However they didnt look at the rego sticker which had expired over a month ago....
Because the car has been off the road for a while i forgot all about it...
Anyways they were pretty nice in the end... I guess they deal with some pretty nasty people everyday. But still thats 20 minutes of my life ill never get back.
Back to the story... Saving at the moment for a full and i mean 3 day type full service and tune... New AAC valve should be here in a few weeks from Japan ($300) then tune and all should be good.... In the mean time ill just drive it a little to keep the juices flowing
OK guys... the problem is solved.... Yes you heard me i fixed it...
Cost $40
Time taken 10 minutes
Faulty AAC Valve... Hardest part was trying to find the part.... Only taken 3 weeks, but anyways not the point... Im over the moon now... I can finally get the new FMIC done in the next couple of weeks... Then is the AVC-R... Then ill see you a jamboree... Wanta (im mean gonna) crack mid 12 second pass....
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
