that is a beautiful base car to start with. Really just needs rims and you're set. The right offsets are crucial as you won't be able to get this thing that low with how deep your kit is.
go for 19X9's in the mid teens and you will be laughing. eg (19x9 +15)
very jealous - but hope you enjoy washing your car, going to have your work cut out for you with black!
  • Replies 46
..dont remind me. :glare:
guys hoping you could give me some advice on a fuel pump. I'm not looking to rack up huge numbers or anything, but would like to adjust power for street/daily use.
a few people have recommended the Deatschwerks 300LPH In-Tank Fuel Pump which is appealing because its e85/ethanol compatible
..or Walbro Fuel Pump GSS342 which does less LPH (255), but not sure if e85 compatible.. could someone confirm? Would it be necessary/beneficial to get the larger Deatschwerks?
so far ive collected 660cc injectors, z32 AFM, boost controller..
Cheers!
My power goal is around 250+.. but... thats not set in concrete. :no:
There is an exhaust system installed, not 100% where it begins (turbo/dump back).. and will most likely get some new cats in there too. I assume there are compliance cats in there. The down-sides of living away from home.. no tools. :yucky: Any suggestions on an exhaust system?
I have a z32 AFM in my hands, and currently awaiting 660cc injectors, boost controller to arrive. I'm still on the search for a FMIC.
I'd like to get most of these in my possession and install it all at once.
Then top it all off with nistune.
As for turbo, I think I might just run the stock turbo for awhile.. then look into getting it rebuilt.. OR a new larger one? ohhhh.. the decisions...
How does that all sound? Feel free to suggest anything..
if you're keeping the stock turbo - the injectors, fuel pump, Z32 etc are not needed.
Stock turbo will run 12psi safely, or 14psi for an unknown amount of time before throwing a wheel.
12psi will get you around 200-210rwkw - if you want any higher than that then you need to upgrade the turbo (hi-flow, GT30, TR43) at which point (but not before) all those other bits will become useful.
if i were you i'd take care of your plugs, coils (if needed), get a high quality oil in, do your exhaust properly, FMIC, get a nistune ecu in, an EBC and the 12V+ mod to your stock fuel pump and get it tuned by a pro - that will net you 200rkw.
if you want any more power than that, its new turbo time - and then you can throw on all thoese other bits you have. you're wasting your time and a tune putting them in before you have a turbo that can supply enough air to take advantage.
EDIT: for your FMIC, check out just jap and their cooling pro turn flow kits.
http://www.justjap.com/store/product.php?productid=19944&cat=&page=1
Edited by SMOKEYC34
dont know what i'm looking at here? weeping rear rocker cover?? v-common..... try screw it down tighter for a quick fix - otherwise it's a pretty simple job to remove and replace.
wait.. that picture wasnt the one i was supposed to upload. lol.. the picture i was supposed to upload was a crack in the front lip..
edit: pic uploaded.
Edited by S T A R 3 3
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
