Hey people,
It brings me much pain to write that I've had my garage broken into & a handful of parts stolen, at home, while I was asleep in bed...
Last week on either Wed or Thurs night between about midnight & 4am some low life scumbags let themselves in to my garage at home, unbolted some parts off my race car (using & then taking MY tools) & also took some other parts I had in there also...
I will be MORE than happy to pay good money for information regarding the matter as some of the stuff taken was of GREAT importance to me...
Parts include:
1. Nissan RB GTS-R manifold, I have only ever seen one other here in Adelaide so they are super rare.
2. Front mount Intercooler kit off race car, which they used my tools to remove.
3. De-lensed & L.E.D fitted custom R34 headlights, again this is totally custom & 100% unique.
4. Rattle gun, ratchet spanner set, various other tools...
5. Turbo which came with the GTS-R manifold, Unknown jap brand.
6. Intake pipe & Z32 AFM (plug wires cut for quick removal)
There is probably more, but for now this is what I know of...
Some of the parts are fairly generic, however, the Manifold & headlights CANNOT be mistaken...
I hand picked that manifold from a small backstreet garage in Japan back in 2009, bought an entire motor (cos the owner wouldn't separate) & have been holding onto it ever since, waiting for a car to put it on... Which finally arrived just 3 days later :(
There is nothing worse than people who steal from private, individuals who work their arses off to get what they have & have fought for everything they own & it's becoming more & more of a problem every day...
Please keep eyes & ears out for any of the above, & if you know something & wanna make some money, PM me :)
thanks everyone...
https://www.sau.com.au/forums/topic/368788-stolen-goods/
A dog is definitely an option. but hard when you're renting... Parts stolen from the Crafers/Stirling/Upper Sturt area so not exactly the kinda thing that happens around here... Obviously someone who knew already or has been here before... There are 1 or 2 suspects at the top of my list who have bought parts off me, who I don't know otherwise but who have been here to pick stuff up... Logically it makes the most sense to be someone like this... So just need to start sniffing around... Pretty spewin I did em good deals on the parts now! :(
I would also like to repeat the fact that I will happily pay good money for info regarding this stuff... Adelaide is a small place... SOMEONE must know SOMETHING!!
Come forth & get cashed up!!
https://www.sau.com.au/forums/topic/368788-stolen-goods/#findComment-5883270
  • 4 weeks later...
More to add to the list of stolen goods...
I know it seems odd to only realise now, but a set of rims were also taken that night... Yet again, a VERY unique set that are like no others...
Didn't realise they were gone until looking for them tonight to show to a potential buyer, but yes, they were in the garage too...
Work VSXX black centre with polished dish... 18" x 9" front & 19" x 10" rears, high offset & have been drilled to suit 5 x 114 as they were originally another stud pattern... will upload pic as long as it lets me.
https://www.sau.com.au/forums/topic/368788-stolen-goods/#findComment-5923785
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
