I finally got time to fit the GTX today, let me say now its bloody huge and only just fits in there. It sat a bit lower than I hoped too, I need to make a 90 degree oil drain to make it work. Everything else, although tight and time consuming, is easy enough to make now. Heres some idea of what I am dealing with...
Thanks Aaron for the help, we set a new record of 1 1/2 hours to remove the stock turbo. :thumbsup:
https://www.sau.com.au/forums/topic/368795-gtx3071-install/
Mmmm...
So when will it get fired up for the first time?
Plenty more work to do yet. :/
There is 5mm clearance from the gearbox housing and 10mm between the compressor housing and the chassis. Literally the minimum I would allow. Lucky our engine mounts keep it nice and tight so it should be fine.
https://www.sau.com.au/forums/topic/368795-gtx3071-install/#findComment-5880299
Na, metal contracts when its heated. She'll be fine :ninja:
not if the engine tilts towards the firewal..
lol the first fit the wastegate entry was touching the wall.. i think after i left he re welded the adaptor.
https://www.sau.com.au/forums/topic/368795-gtx3071-install/#findComment-5880469
dampers are shit and useless
engine mounts are the ONLY way to do it properly
i think the engine twists in the opposite direction anyway. but backing off might make it bump the sidewall?
i think the engine mounts are near solid anyway.. only better ones i think are the nismo ones which are completely solid..
agree with you on dampers.. havnt seen one thats worked as good as doing mounts.
https://www.sau.com.au/forums/topic/368795-gtx3071-install/#findComment-5880659
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
