A week under my car on my back in the cold, and its only just finished. Give me a while to rest please. :)
You would have to buy the turbo, leave your car with me for a week or two and leave a big wad of notes when you pick it up. The result is amazing though. I need to plumb the screamer back in soon, it hits boost too quick to catch the gate sometimes. Its a matter of time before someone hears. :whistling:
Im not removing all my gear, I just installed it... :nyaanyaa:
To make a jig for the exhaust (dump/front pipe) I would need a lot more space than I have available. You saw the state of my little workshop. Perhaps you should wait until I upgrade. lol.
gahhhhhh i call dibs on your used setup...again..!
Its a pleasure to drive, the large housing really improves the low end and gives a more gradual rise in power, like a V8. Its running rich as at the moment so its going to make a few kw thats for sure.
As im running the exhaust temp sensor before the turbo now I can lean out the fuel at cruise, its running 17:1 at the moment no problem, only seeing 650 degrees. It does feel a bit doughy with less bang from the mix but if I get Cihan to tune it a little richer just above cruise it should feel perfect.
Thanks. I cant wait for the tune. :thumbsup:
Anyone have an F-con V pro laying around?
No, but you can get this one :)
http://page13.auctions.yahoo.co.jp/jp/auction/r79506721
The money is delayed for about another month for me so no can do for those $1k+ Fcons :(
Edited by iamhe77
:rofl: I assume all of you kids rang them? Hopeless, the lot of ya :P How much did they end up wanting for it? Was it the 'FIrst edition' of the Fcon V Pro?
Nah, but I did send an email.
Very early Fcon V pro which does not have the option of VQ25det.
Good for R33 GTR though.
Oh, and the price magically changed from $550 to $1000.... lol
Ah cool. Good to know. I take it theres no option to upgrade the firmware on the units?
thats a pretty sweet magic trick!
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
