Yeh, i'm pretty stoked.
The Fcon has changed the whole feel of the car, nice firm adjustable gear changes, an idle I can set, cold start mapping so it fires first kick with the ethanol, no 300kw blip when I roll off the throttle. The list goes on.
I noticed the box wont shift into gear properly at full throttle until its hot, it just bounces off the limiter. I guess that's the gearbox computer's job though.
There was no issue with Cams install either if you listened.
I can adjust the throttle curve similar to the pivot unit but this goes way further, the Fcon controls the throttle directly so no more closing after 5k, blip on pedal release, throttle close on gearchange or whatever else it does.
I have to hook up the brake wire again and see if this engine light will go away. Oh and reconnect the o2 sensor...
Oh, his stock fuel pump was lethargic. Its too late once its strapped to the dyno I guess... >_<
I had faith in your setup Cam, even though I had teething issues with mine. Thanks for the help buddy. :thumbsup:
lol lets be honest, cams wasnt running THAT well. it needed to be tuned. its a shame we didnt get to see that before the end came
Only didn't run "THAT well" above 4500 as the blockage in my fuel filter limited the fuel supply. Everything under 4500 was tuned and running perfectly.
Well it ran perfectly for ~1500kms until I drove into a ditch :(
Nice results scotty well done mate :thumbsup:
Thats a huge torque i bet it pulls harder than a 14yo with a playboy magazine! Lol
Im curious to know how much torque my car produces id also like to see how the same turbo feels on a different motor :whistling:
Our power figures are .4 kw difference but you do have an auto and 1.06 rear housing yeah?
Maxed out the compressor by the looks of it.
I think good tuning on these turbos delivers nice and linear power. The 1.06 housing would remove any tendencies to give you light switch delivery which might make it feel slower than it is.
Mick's car just keeps giving the more you ask of it so it is quick but it isn't scary to drive plus there is still room to tickle the suspension on it.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
