True, no-one can tell me when any part will go bang, there is definitely plenty of load on the gearbox now but its not like I can drop the clutch at 7k, the power comes on smooth and the torque converter dampens the torque output. Perhaps it has some more in it? I would be happy with a safer 350kw by going to the GTX3076 and not maxing it.
jeez someones getting a little sensetive lol.
he doesnt know this, and yes i havnt read of one pooping after reaching its limits either, but i have also not seen or read about a VQ25DET running over 350kw at the wheels. have you?
and im pretty sure no tuner wants to 'pop' a customers car
No, not at all.... I just find it funny hearing that it will go pop running that kind of power when the only basis for comparison is either the RB25det or the VQ35de.
I know of none running 350kw at the wheels... but how many have tried? I've read about the 2.8L VQ25det in Japan running 315awkw but that is running a VQ35de crank and TEPS rods/pistons. I'd love to see and reckon it would be golden at around 350-360 with the 3076 as a reliable daily but it ain't my car nor money and I am only going on what I "feel" the engine could do. All speculation of course :)
Exaggerate much Aaron?
I just found out the VRS top end Nissan gasket kits are discontinued so I hope I can find a suitable gasket kit to do the job. The full gasket kits for a VQ25det through Nissan are nearly $600.
Ok, just for you Alex... :)
Aaron turned up today after he heard the new turbo arrived, he helped me rip his 3071 out and fit the new GTX3076.
I decided to fit the smaller 0.82 rear housing instead of the 1.06 Tial. I was pleasantly surprised at the improvement in response, it seems like it would actually boost off the line now with a little stall. The tune is set for Wednesday night so I will let you know how it pans out.
Sounds good. Great move on the housing. Will change it significantly I think. Video of dyno please!
Make sure get a really good accurate Indication of the speed, we didn't go past 6k because it just peeled over, but that was well off the speedo in 4th. I suspect it's good for 210-220 at your rev limit. Both my tachometer and speedo read significantly high.
Ok, will do.
Gladly the 18's put the informeter speed spot on, only the speedo in the dash is out 10k's at 100. I will try and get footage of that too during the run. What do you want displayed? Speed data will still only go to 180 but that will do as the dyno will be in wheel speed axis anyway.
On second thoughts, does the dyno just store your data from last time? If so, just use what you did your previous run on. You want to see the difference in response, and don't want to stuff it up by messing to much with the speed.
I'd love to see the 71v76 overlayed if possible.
Well, no great results yet, as soon as we strapped the car down to the dyno we realised the slight overheating issue I have been having for a while was actually a blown head gasket. We did a carbon test on the cooling system and got a positive result for exhaust contamination. It looks like either a head rebuild or another engine is going in. It's very similar symptoms to what Gleeson's car is having, perhaps its a common issue/fault? I may look into the pathfinder cooling mod after all Cam. :)
With the boost at around 19psi it was flowing over 330kw still so there is good power there, at least 350 comfortably, perhaps more. Now to find an engine. :(
Alex, the 76 graph looked almost identical to the 71 graph, just at lower boost. Transient response is much better though, looks like a good turbo match for the engine.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
