Oh dear, looksee what has happened now.... We may have lost one of our brightest, consistent and most informative poster's ever !
Damn you, Damn you all
I needed to know so much more..... and now..... i never will
*sigh*
Please come back UNDR8ED; all is forgiven.
Please share your boundless knowledge of how to use unnecessary capitalisation and numerals within words to convey your vast wisdom; we are lost, and have much to learn.
Edited by Daleo
I can't even pronounce his name without help.
Is he under bed ? Thats just plain weird man !
Damn it .....I was wondering if he was ever going to inform us the the m35 doesn't have an RB! :P
Seriously what a f{:content:}amp;ktard!
FARKEN WHAT!?!?!? thats the reason i bought a Stagea for all the plentifull and cheep RB goodies to bolt on :( damnit should've bought a skyline!!!
My GTX3071 made 288rwkw on 98 at 21psi im now on E85 and at 18psi made 307rwkw and on 22psi with major boost leaks got up to 312kw with predictions of theoretical possibility of 350rwkw.
GTX3076 some boys are making 360-400rwkw on E85
so whats the figures on these???
GTX3071.......... is that the stage 1 hiflow option? 270kw max?
GTX3076.......... and this is the stage 2 hiflow ? 270kw+ ?
is that on a VQ25DET with 4WD ? otherwise those figures are kinda pointless...........
altho a HP figure on the crank would be useful :)
I have your GTX3071 at 278.5 as tuned with 98ron. It is a bigger jump with the E85 than you are quoting. Keep in mind my old school GT3076 with ATP TS housing seemed to come on earlier than the smaller 71mm GTX with 98ron.
The claims of 360-400rwkw with E85 might be coming from a certain dyno which seems to produce some higher results than many others so make sure you compare apples with apples. Early results show the GTX3076 to be very similar to a GT3082 aka GT3040. The turbine has proven to be the limiting factor on these turbos.
Scotty has the bigger Tial housing (from memory) so the 76mm GTX compressor will have every chance but ultimately I reckon the 71mm compressor is not the limitation.
It peaked at 288kw but was bought down to a "safe" 278kw :whistling:
Dyno figures for the GTX3076 are in the RB25 dyno thread dont know what dyno was used simply requoting figures
You love bringing up that the ole 3076 comes on sooner than the GTX dont ya mate lol :nyaanyaa:
I'm guessing the current gtx3071 is good for around 320 on ethanol, on an m35, hopefully the 76 can add 30 to that figure so around 350awkw, perhaps a little less with the .82 rear on it. That's the next goal anyway.
Not sure the box will be happy with that figure, even the 33gtr box I hope to slip in may not handle it for long.
These are not highflow turbos, they are large housing surge ported Garrett turbo's with external gating, much more chance of a higher figure.
Will the GTR box drop straight in scotty or will it need mods? Has anyone ever looked into or tried Cryotech for gearbox parts dont know the exact process but they use liquid nitrogen and put them under vacuum i believe and claim that it hardens things by 300% NASA stumbled on it when all the space shuttles returned harder than were originally made? I recall seeing its around $60 a kg or something would be a cheap alternative for a hardened GTR gearbox if the claims are true :blush:
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
