Hoping the shorter pipes and lack of leaks might get me bit closer to your response Andy :whistling:
Goes in this Friday hopefully its all sorted and it can see the 25 psi im so longing to see!
Pressure tested my new setup and it came up trumps!:worship:
Sure do :banana:
  • 1 month later...
We finished tuning late last night, changes were:
The exhaust: it was changed from 3 inch with cat to 3.5 without.
Diff: The car now has a 3.5:1 ratio 350z LSD
ECU: I ripped the Emanage/Vmanage out and slotted in the HKS Fcon V pro.
Fuel was still Eflex e85, boost was capped at 25psi due to it not making any more power over that point. It seems the compressor is maxed out.
I haven't been able to drive it in anger yet, low down it is much more responsive due mainly to the diff. The exhaust works great keeping the Varex valve shut until boost hits for quiet cruising.
Nice work Scotty, as usual.
Out of the 3 things you changed, what do you think gave you most of the extra power; exhaust, diff or management? Or were all three neccessary to progress over what you were running previously?
What extra control does the HKS system give you over the E-manage?
Whats the differences between the red and blue runs on the graph Scotty? I notice one makes more power and less torque than the other...
How did you go tuning the F-con? Much better than the Emanage?
The Fcon gives me standalone control which is the main reason I went down that road. Now I can adjust most aspects of the tune like cold start, throttle, idle speed etc. It seems quite comprehensive from the little I have played with it.
The exhaust was where the gains came from, I ran it in 4th this time thanks to the lower ratio diff, that's why the torque was down on the last tune.
The two lines were different boost levels, I think it lost power with more boost so we dropped it back down.
you might be interested in this??
I'm sure it'll be fine; hardly any sand would've gone through that engine at the 2 min mark; what with the comprehensive air filter system he had fitted...whistling.gif
Edited by Daleo
there are heaps of them in that video. most of them don't crash
i was just amazed at how quick they do an up-hill 1/4 mile~~!!
You're not wrong; that last one basically looks like a Patrol with a doorslammer engine!
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
