Good luck mate what sorta time you aiming for ? 12.? :nyaanyaa:
Yeh Mick, very close power wise.
The car still doesn't feel that quick, its a fair bit heavier than a skyline but the torque obviously helps. I guess I will see what it can do on Friday. :)
i don't finish work in the eastern burbs till 5.30
but there is a few of us planing to come in for a geez, spose we will be there round 7-7.30
ill bring my camera for ya.
Great, see you there. :thumbsup:
At least this time someone will know what a Stagea is. Lol.
I did 13.5 with 240kw, a low down throttle restriction and speed cut by 3/4 track. Hoping for a high 11 this time out but I doubt it due to the weight and RWD.
Haven't got the front diff in?
What have you been doing all day!? Should have time tomorrow morning, yes?
11's will be nice......Good luck and may the boost be with you :thumbsup:
I will be watching this spot for a time slip closely :ninja:
No point waiting, I couldn't get the thing to launch at all. Nearly 3 seconds for a 60 foot is a joke. The 1.06 has to go, time for the .63 rear perhaps?
I had overheating issues also, not just the water and trans fluids but the fuel was boiling too. It would just bog down and missfire off the line.
The trap speed was pretty good, 112mph (180kph).
I was definitely reeling the other cars in but they had me by 3 car lengths out of the hole.
Just tossing up between the .82 and the .63 rear housings as every other way around the problem involves making the car less drivable on the street. (other than going 3.5L :whistling: ) I really don't want to go to a 4k stall converter.
so what was the 1/4 time? 0-100?
Wonder why it didn't launch well. Your old setup did ok didn't it?
You mean yours? :)
The turbo only makes 2 psi at stall and thats after holding my foot flat for a few seconds. Then it just bogs down. I need it to wheelspin off the line to have a chance hence I need the turbo to make full boost (or close to it) by 3k to match the stall converter. I knew this all along but I wanted to see what the 1.06 was capable of.
I ended up with a 13.9 but was going 141.3kph by 1/8th mile after the 2.8 second 60 foot. Only one timeslip as the tards lost the first one somehow. Thats .4sec worse than the last run, back on the highflow with 250kw, speed cut and throttle restriction. Power doesn't make it quicker unless you can launch it unfortunately.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
