I was definitely reeling the other cars in but they had me by 3 car lengths out of the hole.
Just tossing up between the .82 and the .63 rear housings as every other way around the problem involves making the car less drivable on the street. (other than going 3.5L :whistling: ) I really don't want to go to a 4k stall converter.
You might get away with a 0.63 using pineapple juice. It would be waaay more lively and it seems that you have maxed out the compressor anyway.
Even if you drop a few kw at the top end it would be a much faster car all around.
I ended up with a 13.9 but was going 141.3kph by 1/8th mile after the 2.8 second 60 foot. Only one timeslip as the tards lost the first one somehow. Thats .4sec worse than the last run, back on the highflow with 250kw, speed cut and throttle restriction. Power doesn't make it quicker unless you can launch it unfortunately.
First run was only a couple of hundredths quicker IIRC.
.82 would be perfect IMO
Whilst I agree with Wolverine, I reckon the .63 would make it a bit too much on the road.
It's a very, very well behaved (and quick) road car as is, it'd be a shame to see those manners disappear in the name of a good 1/4 mile time.
Edited by iamhe77
I am getting prices as we speak, Tial housings are bloody expensive but I only need the housing, not the clamps. Price with clamps is $670 delivered. >_<
There are Tial knockoff .82 rears on ebay for $289 delivered, perhaps I should get another one of them seeing as I modified the one I already bought. The quality is great.
http://www.ebay.com.au/itm/270940066206?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1907wt_1159
The safe option is the 0.82 but I think you could get away with a 0.63 and not find it a choke point with that compressor using E85.
At that price for the Tial knockoffs it is a shame you don't have an easy peasy high mount manifold with V-bands so you could swap the housings quickly.
I cut it up to modify it but I need another turbo to jig it up, then the exhaust/wastegate would have to be redone. I just want to bolt a rear on this kit for now so I will have to buy another.
If I could take off at good boost he wouldn't have had a chance. Next time... :P
  • 4 weeks later...
I was down at Edge tuning again today after sorting out the boost control circuit and fitting the lower temp thermostat. It was also a good chance to change fuels to United e90 as there is one local now but the extra torque put an end to any fun I was expecting.
3rd gear runs saw the torque converter lockup clutch slipping badly, that and we couldn't work out how to get rid the speed cut with the Fcon for 4th to be very useful. It looks like I will have to upgrade the stall converter again and refit the SLD.
As it was, with 4th gear runs to around 5k it was comfortably hitting 300kw at 25psi (flat finally) If I can get the SLD re-installed I may be able to sneak a tune in this weekend. :whistling:
I'm bloody amazed, as is Cihan that this little 2.5 just keeps taking more...
Considering the torque output Cihan feels it is doing very well. Not that many engines would be taking the abuse this one has, its done literally 300 dyno power runs and lasted 3 years powered up with over 3 bar of boost at times. I'm quite impressed.
I don't have a choice smashing limiter, it happens all the time due to the stupid auto failing to shift in time. At least pinking is a thing of the past...
Still running the 1.06 Tial mate, looking to crack 350kw this time so I will need it.
Its a Dominator custom stall converter, it flares to around 3k when stopped but flares to 4k once boost kicks in (as the revs they stall to is largely torque dependent) The issue is the lockup clutch is too small though, not the stator itself as its a 5 axis billet unit and should be bullet proof.
Not sure yet if I should get another converter made or just cut this one up and get more clutch plates fitted...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
