  • Replies 117
ORIGIN BUMP
Pictures earlier in thread. Postage additional, unless agreed otherwise.
***** N1 Oil pump gear. Using a Billet gear. Can supply used rb25 pump and new crank seal in good condition which has been cleaned. $80 (Oil Pump free)
***** HEL/GK Tech Braided clutch line to suit R32/33 Gtst skyline. Never used ***** WAS $35 NOW $25
***** R32 GTR/Gtst/Z32 Rear alloy knuckles. ***** WAS $50/pair NOW $20
***** R32 GTR copy rear spoiler. Has removable led strip. In fair condition, paint recommended ***** WAS $150 NOW $100
***** Stainless 3 inch dump pipe. Suit RB20/25 turbo. ***** WAS $40 NOW $20
***** Set of EBC Redstuff Front and Rear pads ***** WAS $200 NOW $70 PICK UP OR $90 posted
Happy to separate front and rear (If you find cheaper price I will beat it!)
- Front Pad DP3775C suit 350Z non brembo, R32 non turbo, Maxima, Altima, Cube, Juke, Sentra.
- Rear Pads DP3686/2C suits S13 CA18, R34 GT-T non turbo, R32 non turbo.
##### Please double check part number before purchase. ######
***** RB25 Crankshaft and Camshafts. Both from series 1 engine. Used condition, no damage.***** FREE (Will not post)
***** R32 Type M front bumper (white), in fair condition. Has had both corners repaired ***** $50 TO (SAU MEMBERS)
***** 3 inch cat back exhaust for R32 mild steel. Has rear cannon with broken mount, average condition. ***** FREE
***** 10 inch kicker sub in enclosure ***** $25
Contact by PM or SMS 0432227533. Thank you for reading! :yes: :yes: :yes:
***** Sparco bonnet pins kit. Un-opened packet ***** SOLD
***** GK Tech R32 GTST Radiator cooling panel. Never been fitted ***** SOLD
***** R33 Lower control arms, have been professionally boxed with dimpled sheet metal. (Require paint/powdercoating due to the welding) ***** SOLD
***** Trust/GReddy RB25 plenum throttle body adapter to suit standard throttle. ***** SOLD
***** Trust/GReddy RB25 stainless manifold. ***** SOLD
Back to the top for the weekend, I would love to find new homes for the last of these parts!!!
Pictures earlier in thread. Postage additional, unless agreed otherwise. Sadly I may have to throw away things which are left so arrange pick-up (Brisbane) for the free parts asap!
***** N1 Oil pump gear. Using a Billet gear. Can supply used rb25 pump and new crank seal in good condition which has been cleaned. WAS $80 (Pump free) NOW $60
***** HEL/GK Tech Braided clutch line to suit R32/33 Gtst skyline. Never used ***** WAS $35 NOW $20
***** R32 GTR copy rear spoiler. Has removable led strip. In fair condition, paint recommended ***** WAS $150 NOW $80
Free stuff! yes that's right its free!
***** R32 GTR/Gtst/Z32 Rear alloy knuckles. ***** WAS $50/pair NOW FREE!
***** Stainless 3 inch dump pipe. Suit RB20/25 turbo. ***** WAS $40 NOW FREE!
Back to the top
NEW PARTS ADDED
R32 GTST/GTR Half Cage. Missing the cross bar, also no bolts or base plates. Should suit both 2 and 4 door. $300ono
Turbosmart Eboost (s1 gauge type?), going haltech and have no use for it anymore. $250
N1 Oil pump gear. Using a Billet gear. Can supply used rb25 pump and new crank seal in good condition which has been cleaned. WAS $80 NOW $60 (Pump free)
3 inch cat back mild steel with cannon muffler. Needs some welding to be done, came from 32 coupe. $50
Set of EBC Redstuff Front and Rear pads. (Bought wrong pads for my car. Didn't check on vehicle before returns period expired! My loss is your gain). $70 pick up or $90 posted (If you find cheaper will beat!)
- Rear Pads DP3686/2C suits S13 CA18, R34 GT-T non turbo, R32 non turbo. Please double check part number before purchase.
Stainless 3 inch dump pipe. Suit RB20/25 turbo. $20
post-47150-0-01726800-1403511445_thumb.jpgpost-47150-0-05449300-1403511483_thumb.jpgpost-47150-0-18853300-1403511455_thumb.jpg
Contact by PM. Thank you for reading!
NEW PRICES, OFFERS WELCOME
R32 GTST/GTR Half Cage. Missing the cross bar, also no bolts or base plates. Should suit both 2 and 4 door. WAS $300ono NOW $250
Turbosmart Eboost (s1 gauge type?), going haltech and have no use for it anymore. WAS $250 NOW $200
Set of EBC Redstuff Front and Rear pads. (Bought wrong pads for my car. Didn't check on vehicle before returns period expired! My loss is your gain). $60 pick up or $80 posted (If you find cheaper will beat!)
  • 7 months later...
Added new parts!
I.D. 725cc Injectors and dual feed RB25 fuel rail. $300 and $50
Bosch 044 Fuel Pump Bracket (Brand New) $10
New O2 sensor to suit R32 RB20 plug (May suit other nissans also) $20
Turbosmart Pro Gate 48mm external wastegate. Used working condition $80
R32 GTST/GTR Half Cage. Missing the cross bar, also no bolts or base plates. Should suit both 2 and 4 door. WAS $300ono NOW $150
Turbosmart Eboost (s1 gauge type?), using Haltech. WAS $250 NOW $100
N1 Oil pump gear. Using a Billet gear. Free used rb25 pump and new crank seal in good condition. WAS $80 NOW $40
Set of EBC Redstuff Front and Rear pads. (Bought wrong pads for my car. Didn't check on vehicle before returns period expired! My loss is your gain). $40 pick up or $60 posted (If you find cheaper will beat!)
R32 RB20 Clutch fan (Painted black) and Shroud (Modified to sit flush against alloy radiator) $FREE
3 inch cat back mild steel with cannon muffler. Needs some welding to be done, came from 32 coupe. $FREE
Stainless 3 inch dump pipe. Suit RB20/25 turbo. $FREE
Updated - Most parts now on Ebay
I.D. 725cc Injectors and dual feed RB25 fuel rail. SOLD
Bosch 044 Fuel Pump Bracket (Brand New) SOLD
New O2 sensor to suit R32 RB20 plug (May suit other nissans also) SOLD
Turbosmart Pro Gate 48mm external wastegate. Used working condition SOLD
Turbosmart Eboost (s1 gauge type?), using Haltech. WAS $250 SOLD
N1 Oil pump gear. Using a Billet gear. Free used rb25 pump and new crank seal in good condition. SOLD
Stainless 3 inch dump pipe. Suit RB20/25 turbo. SOLD
R32 RB20 Clutch fan (Painted black) $FREE
  • 1 month later...
Last parts left
Nissan Brake Caliper adapters for 280mm to 324mm rotor conversion. $100 posted
- Made by Unique Auto Sports in Sydney.
- To suit R32/S14/S15
RDA 324mm Front Brake Rotors - To suit R33/34 GTR or R32/33/14/S15 with adadpters $200 Pickup only
- Slotted and dimpled
- Brand new never used
RDA 297mm Rear Brake Rotors - $100 Pickup only
- To suit R32 and R33 Gtst Skyline
Set of EBC Redstuff Front and Rear pads. (Bought wrong pads for my car. Didn't check on vehicle before returns period expired! My loss is your gain). $30 pick up / $40 posted (If you find cheaper will beat!)
post-47150-0-77426200-1403511407_thumb.j post-47150-0-80736300-1403511422_thumb.j
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
