hi all.
looking at a set of cams for a 34gtr motor.
they are HKS 256degree 8.7mm lift.
ive had a quick look but cant find if these are a streetable cam or more track.
they are able to go in with no mods to head,
i understand it all depense what they are paired up with in the car,
cheers
https://www.sau.com.au/forums/topic/368808-need-some-advice-on-cam-shafts/
I think these cams are the smallest duration that HKS do as an upgrade.
They'd be a pretty good street cam IMO.
the duration is longer than stock and the lift is better than stock.
from my understanding the longer the duration the later the power will come on, so a 272 degree cam with same lift will come on much later and have some overlap at idle giving it a lumpy idle.
i think 8.7mm lift shouldn't be a worry for the std springs,
is there any reason why you're upgrading cams? are the stockers limiting power?
i've got a stock head and std cams and am pushing 370rwkw so the std ones are definitely good for that level, and idle and response is the best its going to be.
I agree. Why are you looking at cam upgrade. You can get over 400kw at wheels out of std engine before looking at cams.
If you are going to expense of building tough engine from bottom up then small cams waste of time. I jumped straight to
272 10.2 with first engine then 290 11.7 with next. if you are modifying you cant mess around.
Stick with turbos, fuel, etc and leave the cams till you go for it............ I ran 11.10 @127 back in 2002 on the STD engine
with bolt on 2540s and bigger injectors.
Depends what you want but make sure all parts match. 34 engine will make great power with bolt ons.
How fast do you really want to go?
Im after a legit street spec engine. I would say 300 or so at all four wpuld b nice. So say 340rears.
Will i gain much with cams, cam wheels etc? Or is the gain just small b4 the 400 mark?
Lag is an apsolute no no
I was thinking
Stock turbos with upped boost
Fuel pump
Inj
Power fc
Cams
Good turbo back zorst
No need to do intakes as i want it clean...
Dont really need much more power Wise...??
Coolere legit, stock turbos are fine for low to mid range with a decent strenght to hold a bit of pressure
leave the stock cams but get adjustable cam gears and replace the stock turbos with N1's (-7s) or -9s, the standard ones wont last at (and probably wont even make) that power.
also there wont be much if any difference between RWKW and AWKW, certainly not that much at that level
If ur talking standard r34 turbos I've seen them make 294rwkw, but were soon swapped out for 2530's so don't know exactly how long they'd last, but they won't last long at all, best turbo for 350awkw in my eyes would be 2530's. They work real nice with great response for that power on a standard 2.6l Motor
Yep 2530s are the go. Years ago I went to 2540s and they KILLED the respose and bottom end.
I've got -10s now on my 3.2L and they haul ass from right down low but would be a bit lagggy on 2.6L
For 350rwkw you should not need to touch the cams or internals at all. Agree on cam gears though.
Back in the day we went as high as 396rwkw using the std cams and std internals (of course at that power
the std internals did not last long!!!)
Yeah ok, is the 2530 a direct bolt up, and r there diff models? I no that my 2535 ive gpt on stag was a 56t or sumthing??
Has any one got results from
Power fc
Cam gears
Fuel pump
550cc ??? Inj
Airbox seems more than enough and looks nice
Then with 2530s?
Whats the point behind the hard piping cooler kits n
So on? Replacment or a mod!?:s
Excuse my lack of gtr knowledge :)
Also do 040s fit in easy? Didnt like the looks of the nismo pump at 600 on ebay lol..!
The hard pipe kit is a good upgrade over the plastic (shitty) pipes when running above stock boost.
But seriously, speak to Willall (club sponsor) who has done all the homework on these things already and has taken all the guess work out of it.
Martin will be able to point you in the right direction quickly as to what to do.....and more importantly, what not to do.
Do it once...do it right...and save a packet in the long run.
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
