not sealing properly..
sickaflex the surround outside the headlight, take the back off and allow the inside to dry.
re install.. try not to get water on it for about a day..
either that or pull them apart and start from scratch resealing them..
paint the insides black too :ph34r:
Hey Guys,
Anyone else suffer from this problem?
Solutions?
Cheers, Mike.
I assume you guys have checked the obvious things, ie the oring on the back is in tact & it is completely sealing when you close it up?
had the same problem, Dunc is on the money, the rear access panel wasnt sealed up properly
I think they are on properly, I don't know if I'm special or what but they were a real pain in the ass to get back on after i replaced some globes, is there a trick to it?
I noticed there is an arrow on the covers but do they line up with anything, couldn't see if they did...
Mike.
