Hi guys,
I've got a '95 R33 GTS-4 currently at the workshop having new motor from Series 1 Stagea put in, however the stagea motor was from an automatic...
Talking to the mechanics there are a few plugs missing from the stagea loom compared to my GTS4 one for ABS, Wipers etc...
Does anyone know if I'd be able to run a engine loom from a manual R33 Series 2 GTST??
Cheers
Dan
https://www.sau.com.au/forums/topic/368836-gts4-turbo-conversion/
Yes S1 stagea has what you would call series 2 RB25DET so coils at least will be different. You will need to upgrade the ecu as you suggested - I don't think you will need to change the loom but if you get the loom, with it you may as well.
But don't use the Stagea loom and ecu - it is an oddball 3 row ecu and you will have problems if you want an aftermarket one later.
Thanks for all the info guys, I'm be putting in aftermarket computer to run it;
What are peoples recommendations I won't be going for big numbers, so would you recommend just a Nistune or Power FC...I've read a few threads saying not to get Greddy Emanage.
I'm just looking for budget at the moment as I just got back from an expensive holiday can always upgrade later.
Cheers :)
Tuner's choice man, there are are few threads on these forums with Nistune vs. PFC, I'd probably go PFC for R33 since they're quite cheap these days; most tuners are happy with them and they are the easiest to install without losing vct or modifying loom for Z32.
I have a Nistune on my R34, they will both make the same power at the end of the day.
