My clutch has recently died on me. I have had it replaced. It is where i press the clutch pedal and it just falls flat on the firewall and doesnt come back up. I found that the problem was a broken Clutch Pivot Ball. the one that connects the clutch to the transmission.
I would just like to know what is the cause of this? and whether there is much stronger Clutch Pivot Ball and where can i buy one?
Thanks in advance :blah:
https://www.sau.com.au/forums/topic/36885-what-happened/
Hmmm, not sure what you mean by a 'Clutch Pivot Ball'. Are you talking about the slave cylinder???
Are you sure that the system has been bled properly? The pedal dropping to the floor and not returning usually = too much air in the system.
Slave and master cylinders can be resealed and resleeved, there may be lots of crap between the seals and the bore.
Otherwise, dunno dude!
https://www.sau.com.au/forums/topic/36885-what-happened/#findComment-744096
