Hey,
So I was in the process of putting my Nismo 555 injectors back into my RB25 rail when I came across a couple that are being difficult, any way as I was out in the shed looking for my silicone spray my effing numpty of a brother in law decided to try and force it in with a pair of adjustable width pliers. :rant::rant::rant::rant:
He has managed to push the little cap in the centre of the injector down about 3 mm and then tried to pull it back out. Would this mean that the injector is now stuffed??
Good injector
Bad injector
Sorry about the picture quality I just took it with the iphone
If it is stuffed can anybody tell me if you can buy them singularly and point me in a direction on where to get them.
NOT HAPPY
https://www.sau.com.au/forums/topic/368897-did-he-break-my-injector/
Umm, let's just say he is no longer at my house and I don't think he will be back for a while.
I hope the pintle is nothing but I wonder if it has anything to do with helping control flow or something? Like does it move up and down?
Pretty sure those act like little valves and move up and down.the injector has a solenoid in it. That controls the injector opening and closing. It controls how far it opens. That thing there moves up and down to let fuel pass through. I think it's rooted dude.
Don't stress. I reckon it could be alright. Like Tazzy said get it tested. Put it in ya car and see if it works. If its broken get him to buy you a new one. Rule number one with assembly: If it wont go then check it, everything has its correct way of going together. There is a thread on injector installation on this site somewhere. All my injectors couldn't be pushed in by hand. Sargerx8 ya wrong mate it don't have no fuel up the top there, hence the term "side feed injector". And that bit aint a pintle fella's. Sounds like some blokes need to read up on how injectors are made and work :D
Spewing you let your brother in law have a crack hey?! Get it in the rail and try it man. It might work??? I don't know if it will or not. At the end of the day its not a lot of money to get a new one and if you have to wait a week to get it well that wont kill you. Waiting for car parts makes it all the more worth it when they arrive I reckon. Let us know how you go with whatever you try.
Didn't really let him have a crack at it, I was putting them in the rail inside (it's warmer in front of the fire) when I got a sticky bugger that wouldn't go in. So when I went outside to my shed to get the silicone spray he took it apon himself to have a go at it.
I spose he was just trying to help but still pissed me off, he is in no way mechanically minded so should've just left it alone but what can you do what's done is done.
Anyway I have some good news, I went for a drive down to UAS and showed the injector to Dave (T04GTR) and he has given it the all clear and said it's nothing to worry about.
Apparently the little metal peice is just something that is used in the molding/plastic injection process to give the machine something to hold onto when it's put into a die.
Dave also said he has seen them in MUCH worse states than mine (snapped of completely, bent & even missing altogether) and they still work fine so that's good to know. I trust his judgment as he has a very good rep and has built some wild engines so he knows whats what.
Oh yeah, 1 weeks wait is nothing ATM. The car has been on blocks since November and will still be for a little while yet ;)
I asked the same question, they do have a solenoid in them but you can't see it from the outside. As I said above he has even seen injectors with that part missing and it hasny made a difference. If they where a top feed injector it would be a different story.
i just called it a pintle cause i didnt know what else to call it.. :unsure:
Hahaha me too, I just started copying you!
I know they are side feed but they way they work is fuel coming in from the side and a valve moving up and down and the pressure in the fuel system will squirt the fuel through the nozzles. I never said fuel goes in from the top, I said its the top of a solenoid which moves up and down controlling fuel flow, which is correct.
If you disconnect the power to the injector, it wont push fuel out. Sure it will get fed into the side but the valve wont move up and allow fuel to be squirted.
The only part I guessed about is that part being a moving part but my concept is correct.
Edited by SargeRX8
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
