Very very very regretful but urgent sale.
Your chance to own a very clean and basically stock example of the legendary "Godzilla".
Recent compression test came back perfect with 155-160 psi in all 6 cyl.
Just serviced with only quality products. Car runs like brand new and will not disappoint.
137,000 kms
Apexi 3.5" exhaustt
Nismo 320km/h dash
Nismo gear knob (original also included)
Nismo clear side indicators (originals also included)
Carbon rear wing (original also included)
Alarm with built in turbo timer
R34 wheels
$2,500 stereo
6 months rego
Also included but not fitted:
N1 steel wheel turbo rebuild kit x 2
N1 oil pump
N1 water pump
Note:
Slight paint fading on a section of the roof (quoted $400 to respray)
Drivers window has common problem where it needs to be 'helped' up and down (approx $200 for replacement power window motor)
Any mechanical inspection or test welcome. Only selling due to the purchase of a business and I am leaving the country for a month so the extra cash would be nice. I fly out on the 15th of July which is fast approaching so must sell fast! I have not owned this car very long and I am losing bulk money on it. Im sure first to see will buy.
Please call, sms or email anytime
NOW $17,000 BARGAIN!!!
Reece
0420 370 659
[email protected]
PS: I am willing to send interstate for only $500
Guest
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
