looking at the graph, i'd say that only a small percentage of the difference in pressure is due to restriction in the intercooler. the reason being that as airflow increases both the before and after pressure decreases at roughly the same rate. if it was a restriction the pressure before the turbo should increase while the pressure after it should decrease reletive to each other. you have to remember that the pressure after the intercooler will always be less than before the intercooler due to cooler air being more dense. depending on your before and after temps this could account for up to 10% of the drop you are seeing, and would defininately account for between 5 to 7% of the drop.
oh and FYI, the stock setup actually runs the wastegate off the cold pipe. when i put my fmic on i cut the stock nipple off and welded it onto the hot pipe. this made it hold boost much more stable. was getting spiking with it running off the bov line.
"if it was a restriction the pressure before the turbo should increase while the pressure after it should decrease reletive to each other"
That doesnt make any sense.
If what you mean is that you expect the pressure after the intercooler to drop as the airflow increases then yes marginally by not this much. You mention numbers like 7% and 10%. The pressure drop up to 4,000rpm is only 2psi but increases to almost 5psi in the top end. That is a lot more than 7 or 10%.
Intercoolers normally have a rating of less than 1psi drop at 15psi etc.
Not to mention Trent was the one who was telling me that the shapes should be similar if the intercooler is flowing well.
The stock configuration on my R34 GTT definitely gets the pressure signal from the hot pipe (turbo to the intercooler).
  • Replies 42
Posted Images
Doesnt the factory WG run off the intake pipe? I cant remember but mine is connected to the inlet manifold now..u think would it be any better off the hot pipe?
yeah i think a new muffler would be an eaiser way to go about it..I looked at mine today and thought stuff that ;)
The factory wastegate runs off a nipple on the hot pipe, well it does on my R34 anyway. The intake pipe has 2 connections, a bov return and a breather hose from the pcv. Not to mention there isnt pressure in the intake pipe, only a possibility of vacuum.
If the exhaust is too loud or it is too hard then I will look at a new muffler but I cant see why it cant be done nor am I satisfied with how it is currently.
Mate what i used is the die grinder so that should get you out of trouble. Its a dog of a job but to make it easier once you penetrate one part use a chisel to break the rest Of the welds.
and you are running 33% more boost than 15psi, and i would hazard a guess that the restriction they have is not linear, but exponential. so factor in, lets say for arguments sake, 1.5psi of pressure drop simply from the drop in temperature, and about 1.5psi of drop from normal restriction of a decent flowing intercooler, at high rpm you are only losing around 1% of flow from your intercooler.
my point is, i can pretty much garantee that you won't see all of that near 5psi drop magically disappear with a new intercooler. my guess is that you will still have about 3psi of difference.
as for what i said about the wastegate taking the reading from the cold pipe, that is true for the r33. i wasn't aware that the r34 is different.
as for the initial post about how to remove the restriction from the exhaust, just simply cut cannon off and put a new one on with a 3" ID baffle pipe. it will probably be noticably quieter than what the fujitsubo one will be with the restrictor removed (since in the thread you linked to the guy said that it made his car noticably louder) and still flow just as well.
im realy interested in the new kakimoto full mega N1+rev, wonder if this has this restrictor in it aswell, because it complies with the 93db JASMA rating hmmm
What i personally think is whenever they mention jasma approved means they just stick a restrictor in to make it approved. Instead of actually putting decent muflers they take the short cut as many ppl will never know and be happy with the appearance of the exhust from outside and happy with the sound so will never investigate further.
Yes it does
had that before and its quieter than regu06R
the new N1+rev was the first exhaust which made me aware of the restrictor
Nope exhausts after turbos are different. Bigger is better everywhere in the rev range. Better flowing exhaust only has the potential to reduce lag.
Whats the point in a 3" exhaust when it reduces to 2.5" in one location, might as well have a 2.5" exhaust.
http://www.team-integra.net/forum/blogs/michaeldelaney/103-advanced-exhaust-tech-ii-backpressure-area.html
So you are saying that putting a 5" exhaust is better?
From my limited experience and knowledge, it's about velocity of the exhaust exiting. Blow on a thin straw using X amount of force vs a thick pipe. Which one has gas escaping faster? Then blow 10 times harder, and the thick pipe will flow better.
2.5" at the end of the exhaust is definitely different from having it in the middle or upfront.
In the end, it depends on how much power the car is making, and where in the range the power is wanted.
Why don't you use a set of cobalt drills and just cheese it and see if that makes a difference? Buy a 10-15mm bit and say a 5mm bit. Use the 5 as a starter and then finish with the bigger one.
Otherwise stones/tungsten carbide bits in a diegrinder tool or drill will do it if your patient. The other method is a hole saw, but it would have to be a good qual one for s/s and a big one, say 4" and good luck holding that [it can be done but will be a bitch to control].
Yes a 5" exhaust would be better. Sure you would not see much of a gain at the power level we are talking about, but you would not see any negatives apart from trying to fit the bastard somewhere!
You are getting mixed up with N/A cars like the integras in the link you posted. There is an article on the garrett site confirming this that bigger is better after the turbo.
Yeah I realise I wont defy physics and get the full 5psi pressure drop back. I am hoping with a better intercooler the after intercooler shape will be the same and at most be 2.5psi pressure drop in the top end.
The history with this intercooler is that I have never been able to run more than 15.5psi above 6,500rpm no matter what I do. That is with 2 different turbos, the other turbo was much larger and was proven to run 20+psi above 6,500rpm on other rb25dets. So I believe this test proves that at the very least that the intercooler is at least quite restrictive at higher airflow levels.
+1 for 5" exhaust would be better.
For a turbo car the turbine and housing create back pressure for the exhaust valves. However a huge exhaust like 5" means the idle and response below 2000rpm would be a bit different.
Anyway modifying your exhaust restriction is the first thing you should do for any setup. And for yours Harey it the next step before you can consider any other mod that would normally yield or unleash more kw. ie there is no use doing other mods if your exhaust restriction is the defining feature. So IMO its a no brainer, the only question you have to ask is grind vs replace?
Bigger is better for peak power, and creating more noise. I would appreciate it if you can show me the article that says bigger is better for all rpms.
The link I posted earlier does include tests on turbo cars as well.
http://www.team-integra.net/forum/blogs/surferx/25-exhaust-basics.html
http://www.team-integra.net/forum/blogs/michaeldelaney/26-advanced-exhaust-tech-i.html
Edited by eron
Bigger is better for peak power. I would appreciate it if you can show me the article that says bigger is better for all rpms.
Here it is:
http://www.teamswift.net/viewtopic.php?f=2&t=7628&view=next
Agree! I dont see the harm in grinding first, seeing if its acceptable noise wise etc. Then if not I purchase another muffler.
Thank you.
This is from the article:
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.â€
Thank you.
Yes exactly, going bigger then required wont net you any gains but it wont loose anything.
These are the 2 paragraphs before your sentence:
"Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range."
Not sure how it could be stated any clearer than that?? If you want to discuss this further please create your own thread.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
