Apexi 161AN001 N1 EVO Exhaust System BRAND NEW IN BOX & BUBBLE WRAP.
Removed from box for trial fitting only, mufflers still in bubble wrap. Have decided to custom build exhaust rather than use this one.
To suit 95-98 Nissan BCNR33 Skyline GTR & GTST
Pipe Diameter.: 85 mm-95 mm
Tip Diameter.: 115 mm
Will freight at buyers expense. Box measurements for you to work out postage cost:
2500cm L
30cm W
52cm H
Approximate weight - 10-15kg (can weigh if need be, just estimated)
Pick up available in North East Vic - near Shepparton.
More info taken from web:
"The N1 Evolution combines all the racing heritage and proven performance of the original N1 muffler but raises the ante by adding light weight, fully polished stainless steel piping. This is the ultimate N1 exhaust system. Mandrel bent, full stainless steel construction provides maximum power gains and resistance to rust or other damage caused by weathering. Like the original N1, the N1 Evolution uses the minimum amount of pipe bends to allow for greater exhaust flow. The N1 Evolution was created for those who are looking for something one step further than the classic N1 design. Available only for a select amount of vehicles, the N1 Evolution stands as a brilliant testament to exhaust system fabrication.."
$1000
https://www.sau.com.au/forums/topic/368983-fs-brand-new-apexi-n1-exhaust/
  • 3 weeks later...
  • 4 weeks later...
You can get it for $770 brand new with one year warranty from Ark design
Not according to their website
Go on ebay and there is one for $770 and they are arc design. Located in Melbourne brand new 1 year warranty im 100% sure of it because i rang them today
I think you need to get your facts straing before posting crap in othre peoples threads.
ARK designs aka access_online aka access autoworks are selling them for $799 on ebay
  • 2 months later...
  • 2 months later...
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
