So i have an issue with my afm but need to identify it!
It is a series 1 r33 so i was advised it should be a FIVE pin GREEN one.
But checking my afm it actually has 3 plugs (didnt check colour because its been painted over)
The model is a 95 model so late S1.
Does that mean i need to swap it for a S2 AFM ? :S
Thanks in advance!
https://www.sau.com.au/forums/topic/369001-afm/
easy check to confirm it is a series 1 is to see if it has the ignition module mounted on top of the coil pack cover towards the rear of the engine. If it doesn't have this then it's a series 2. My series one afm has 5 pins so the series 2 must have 3 then.
https://www.sau.com.au/forums/topic/369001-afm/#findComment-5882820
