  • Replies 47
I've raced an autech and it was slower then my rs4s. Maybe just a bad day for the autech but my turbo only held 10psi for 1000rpm before fading down to the poo level of 4-5psi. I think that there may be easier power making mods with the 26 but stock 25 and 26 appear pretty identical.
And hell yes rbd2 I want to see a pic
Is this the same race where you beat a VE SS Sportswagon and your boss's F6?
:rofl2:
jks!
you can easily extract more power out of the rb26 for less $$$$ basic exhaust, more boost and retune should net you 200-220awkw
same mods on a rb25 will only get you 170-180awkw.this of course doesn't take into account the difference in purchase price(which was only $5g when i bought my rs4
i know from personal experience thru the hills, the autech walks away from my stagea and we have the same basic mods, and my car isn't crazy slow either.
If you beat an autech only running 4-5psi then i suspect he wasn't really racing.:thumbsup:
Ironpaw -i understand your joking but go find yourself a ve redline ute and have a race, from 80-150/160 I sat beside him then he crept away. At 180 speed cut his tail lights were only a few meters in front of my headlights. That's the closest race I've had so far. But that said. I miss my stock turbo :'(. Stupid hypergear turbo is driving me nuts.
Big fella - I got mine 4years ago. At the yard an auto was 15990, manual 21990 and 260rs 29990. The only thing I regret is having un replaceable brake pads.
Edited by lilcrash
It drives fine, it's getting a nice consistent 7psi until high in the revs then in a matter of 300/400 rpm hits boost cut 14psi so I can't go above 5000rpm when the cams hit and my car should be going its best basically
Edited by lilcrash
so its boost creeping?
why dont you get a bigger puck welded on and largen the internal wastegate.. mines currently doing it at 22psi.. hypergear said they'd do it for $120 i think.. should definitely stop your creeping issue
It doesn't do it all the time, it's like the wastegate gets stuck open then suddenly jams closed. If you move the wategate by hand it does get stuck but where the sticky spot is it shouldn't open that far.
then your actuator reach is to long.
or you dont have pre load so its already a little opened, so when it completely opens, perhaps it opens to much...thats alot of opens..
i'de be speaking to hypergear as it obviously should be happening.
He said there is no way it would reach that far. It's got about 6mm of preload
get an air compressor connected to the boost signal like to the actuator. and se how many degrees it opens.
to a shop its always a case of "nah will never do that" as they then dont have to fix theyre fault.
if your having issues like that its definitely not safe. hence the reason im on eFlex
The turbo was originally fitted with a high pressure actuator made to hold 18psi. Been told its too strong so I sent him a low pressure actuator. I have no idea how that was fitted as well as the rest of the bits. The actuator only pushes about 60 degrees out of a 33mm disc covering a 30mm gate which's not enough for it to hit the backing housing and if it does jam open then we should see very low boost.
When I sent the low pressure actuator I don't have the turbo on front of me and I don't how long the rod needs to be but longer is always better then shorter, so if its too long then just cut and thread it down to size, and 6mms of preload is way too much, should be 3mm. I don’t get how it can run 14psi then goes back to 7psi. I have a feeling some of the vacuum plumbing is a bit strange or it is too much actuator preload. I'm guiding a novice DIYer and its pretty hard work. :/
The car's needs injectors and a tunned for 18psi. Its not going to make much more power with stock tune and factory boost. And have to say its doing pretty good keeping up with a RB26dett stegea.
I'm in no way a novice DIYer. Most of my job is custom fabrication.
The high pressure actuator gives in stable boost as the wastegate is held open.
There is no vacuum out put on the turbo outlet so I have used the nipple on the next piece of pipe to the intercooler.
Next point. It's got 6mm of preload because that's all the thread that's on there, at 3mm preload it barely had any boost.
I only wish to run 10psi until I get the other parts.
JUST SO EVERYONE KNOWS. THE ATR43SS-1 THAT I GOT FROM HYPERGEAR ISNT CAPABLE OF LESS THEN 16/17 PSI. SO BEWARE.
Edited by lilcrash
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
