  • Replies 207
Andrew, are all the rounds going to be “made up tracks” held at race circuits or is the series going to start using the full race track. I understand you can’t use all of the thunderdome due to the track condition but what are the plans for Round 2 at QLD Raceway?
Would love to bring our S15 to run the series, but would not suit the track seen in the video and the same would go with a lot of other dedicated time attack cars.
I wouldn't be too concerned Harry about an advantage.
There was only 3 of them doing full laps and they did maybe 5 laps each on the final design? I was driving my Touareg! and only was only driving it through the high speed S section on the back straight. (I never did a full lap even as a passenger. I never even went onto the bank - but I have driven it back in 2006)
So given a) the track will be fairly different with water barriers to what it is with witches hats, b) the track will be different to the test day - it was more a concept design day to an exact lay-out design and c) everyone will do probably 20-30 laps before timing even starts I wouldn't worried about the guys who did a few laps having a huge advantage.
Yeah there was only 5 laps of the final course design done, and that was with me as passenger.
That said it won't be 'identical' anyway IMO as it was only rough positioning to see how it would work. I'd support even a longer back section for more speed lol, that would totally change the course dynamic again.
Calder is the only custom built course we are using. The other two rounds this year are on "conventional" tracks. We wanted to try and differentiate our event and do something special for the first event. For next years 5 round series we might use the big track so time attack cars dont have to change their set-up.
The guys testing the course can compete, yes, but tje final layout will be slightly different with proper corners built instead of cones.
Ones thing for sure, its wild fun. Im going to set JET200 up for it for sure!!!!
I don't know if practice the day before the event allows quite the same opportunity to change your setup to suit a track no-one else gets to run on as practicing a couple of months before everyone else. It feels a bit like allowing a competitor to course check a blind rally to me.
That is great news. Will defiantly be bringing our S15 out for these events then :banana:
Everyone is on same boat so level playing field
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
