The m35 came with a Carrozzeria (jap Pioneer), good unit but only for japanese so i reefed it out and went for a single din setup with a pocket. (no point in having to massive screens in one dash)
I was having a few issues with head unit sizes they all were like 5mm to big on ither side and i wanted to stay with pioneer so i could keep all my loom colors the same as the Carrozzeria unit.(easier swapout) So in the end i went with a Pioneer MVH-8250BT (autobarn) and actually had to mod the face of the unit to get it in (void warrenty so dont do this unless you have to). If you look closely at the picture of the head unit you will see two small little plastic facia bits on iether side. I broke them off and then cleaned the surface with a females nail file so it comes up nice and smooth.
The Nissan pocket purchased from Autobarn didnt fit infront or behind the factory plastic so i carved the face off with a stanly it doesnt look to bad but you can see a 3mm gap around the face of the pocket. ill head down to clarks rubber later and grab some really thin rubber or foam seal and run it around the face of the pocket to fill the gap.
P.S. I have a Carrozzeria (with loom) avic-zh25md for free if any one can understand japanese and wants a nice big pretty screen. (postage or pickup is upto you)
Edited by loymclure
https://www.sau.com.au/forums/topic/369011-m35-double-din-stereo-replacement/
most aftermarket head units use the same wire colouring anyway.
looks really good in there! where did you get the double din centre console?
do you have an AXIS as that looks like an RX interior and AFAIK they only came with integrated stereo
Pretty sure it says RX on the back lol cant remember. The console came with the car so i dont know if its from factory or if it was put in with the carrozzeria.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
