hey everyone.
my 32 rear subframe lower part leaks a little bit after long drives when i stop it comes out slow its like dark brown close to black sticky leak from the bush no one has had this problem, hopefully someone here can tell me. friends have said to replace with pineapples. but still no one has said they have anything in the bushes area so why would it leak ??
cheers
AndreW
Edited by AndreW_R32
https://www.sau.com.au/forums/topic/369052-r32-rear-sub-frame-leaking/
The bushes are oil filled. They have cracked and are leakibg.
Couple of options
1- remove subframe and press in new bushes or pinapples.
2- lower subframe and put in subframe c lock spacers. This removes the slop that the worn stock bushes have. But also create some NVH.
Mine were leaking too. Seeing as I track my 32 occasionally I decided to put the C locking rings in mine. TBH I haven't checked if it still leaks LOL but it definitely stiffended it up in the mean time.
I'll probably look at replacing them one day.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
