all exterior parts(white immaculate condition)
18" rims with tyres 235 front 265 rear
motec m800
rb25det with forged pistons and rods, cams, cam gears, stainless top end, strengthened crank (less than 30,000kms since rebuild)
5sp manual gearbox
lsd rear diff
nissan 4 pot front and 2pot rear brakes (EBC green stuff pads, dba 4000 rotors less than 2000kms old)
rear axle shafts
lightened and balanced tailshaft
garrett gt35r turbo
k&n filter
2x front facing plenum
80mm throttle body
stock throttle body
2x top mount exhaust manifolds
48mm turbosmart progate wastegate
turbosmart veeport bov
hks ssqv bov
300kph nismo cluster
880cc denso injectors
bosch high volume fuel pump
high flow custom injector rail
splitfire coils
polished rocker covers with breathers & catch can
turbo back 3" exhaust
bilstein shocks
king spring SL springs
all whtieline bushes
radiator
power steering pump
a/c compressor
a/c condenser
alternator
m spec spoiler
vented bonnet
2x short shifters
tail lights
nismo side indicators
all interior parts
black gear/handbrake boot with white stitching
all original windows
2x defi bf boost and oil temp with sensors
greddy pillar dual gauge pod
AND MUCH MORE JUST MESSAGE ME FOR ANY PARTS/BOLTS ALL PARTS ON VEHICLE ARE AVAILABLE
0401439396
vehicle made 480rwhp and was all in good condition when removed
https://www.sau.com.au/forums/topic/369074-wrecking-r33/
Hey man I'm interested in your center console and gear surround (including gear and handbrake boots).
how much? What's your location? Will u post to Somerville 3912?
https://www.sau.com.au/forums/topic/369074-wrecking-r33/#findComment-5884155
  • 5 weeks later...
Hey can you pm me details of:
Dump, front and cat pipes, the size, if it's stainless, and if it's high flow cat.
Hks Ssqv, how old it is, what's involved in fitting it to a gtt
KN filter is it pod?? How old is it? What material is it??
18 inch wheels, pics?
Can you also include price on all of them??
https://www.sau.com.au/forums/topic/369074-wrecking-r33/#findComment-5957815
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
