all exterior parts(white immaculate condition)
18" rims with tyres 235 front 265 rear
motec m800
rb25det with forged pistons and rods, cams, cam gears, stainless top end, strengthened crank (less than 30,000kms since rebuild)
5sp manual gearbox
lsd rear diff
nissan 4 pot front and 2pot rear brakes (EBC green stuff pads, dba 4000 rotors less than 2000kms old)
rear axle shafts
lightened and balanced tailshaft
garrett gt35r turbo
k&n filter
2x front facing plenum
80mm throttle body
stock throttle body
2x top mount exhaust manifolds
48mm turbosmart progate wastegate
turbosmart veeport bov
hks ssqv bov
300kph nismo cluster
880cc denso injectors
bosch high volume fuel pump
high flow custom injector rail
splitfire coils
polished rocker covers with breathers & catch can
turbo back 3" exhaust
bilstein shocks
king spring SL springs
all whtieline bushes
radiator
power steering pump
a/c compressor
a/c condenser
alternator
m spec spoiler
vented bonnet
2x short shifters
tail lights
nismo side indicators
all interior parts
black gear/handbrake boot with white stitching
all original windows
2x defi bf boost and oil temp with sensors
greddy pillar dual gauge pod
AND MUCH MORE JUST MESSAGE ME FOR ANY PARTS/BOLTS ALL PARTS ON VEHICLE ARE AVAILABLE
0401439396
vehicle made 480rwhp and was all in good condition when removed
https://www.sau.com.au/forums/topic/369074-wrecking-r33/
Hey man I'm interested in your center console and gear surround (including gear and handbrake boots).
how much? What's your location? Will u post to Somerville 3912?
https://www.sau.com.au/forums/topic/369074-wrecking-r33/#findComment-5884155
  • 5 weeks later...
Hey can you pm me details of:
Dump, front and cat pipes, the size, if it's stainless, and if it's high flow cat.
Hks Ssqv, how old it is, what's involved in fitting it to a gtt
KN filter is it pod?? How old is it? What material is it??
18 inch wheels, pics?
Can you also include price on all of them??
https://www.sau.com.au/forums/topic/369074-wrecking-r33/#findComment-5957815
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
