S13 5 Stud Conversion, R33 Gts 4 Pots Or Gtr Brembos Both With Or Without Discs
Hi Guys,
I am after the following to fit a R31
1) 5 stud conversion kit to suit s13 front and 5 stud conversion for the rear
2) R32 GTR/R33 GTS brakes or better (GTR Brembos) front calipers with or without discs.
3) RB25 breather hoses
4) RB30 oil dip stick
There is no kit for rear that I know of? All u can do from what I've found is redrill the axle of full custom work
I have a full 5 stud conversion kit from an S15. Comes with DBA slotted and cross drilled front and rear rotors with near new pads.
PM me if you are interested
Hi , I do have in Brisbane brand new 5 stud kit for S13 Front and Rear with OEM bearing in it.Manufactured for EU,JAPAN and US market .Easy to install, just swap them over and no other parts required except re drill your rotors to 5 stud .
With this kit you DONT need knuckles or arms or any other parts at all.
Brand new still in the box 800$ plus freight if need.
No made in china or some cheap backyard made .
Got full set of R32 GTR brakes calipers and rotors F & R
or R34 front full set rotors and calipers .
Edited by familka gtr
    • To do the ones around the fuel tank, as in the external ones, you'll likely want a hoist, and to drop the tank. That's the way I'd do them again anyway.
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
