Hi i am rebuilding my engine its an rb25 std bore and motor has done 110,000kms and there appears to be little if no wear in the bore
i am purchasing a set of CP Pistons and a set of Manley Connecting Rods with arp rod bolts for the rebuild and a set of cometic gaskets.
I havnt built a nissan rb 6 cyl engine before is there anything i should be aware of rebuilding it with forged internals as i want to do it once only
When replacing pistons is it recomended to have engine block rebored with oversize pistons or use std size forged pistons
any info would be great i dont want the engine for high horsepower but i want a bit of overkill for the mods i have and the couple i want currently have 430hp hi flowed nissan turbo hybrid fmic a gtr style intake manifold s/steel exhaust manifold low mount 3 inch turbo back exhaust with 3 inch cat and piggy back ecu on to main ecu
thanks for reading this post
Sam....
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/
  • Replies 59
You need to be more specific - what is your power goal? Do you need a rebore? Measurement will determine that - how much oversize and out of round. Also measure crankshaft for wear. If the mileage is genuine it is possible you will be able to use standard pistons bearings etc. Have a read of the oil control thread re restrictors.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5883676
are you capeable of doing the work yourself? do you have the tools to measure clearances etc? if no then just pay someone to do the machining and assembly of the motor. regardless of the bore condition i would certail go for a rebore to the next size up. start fresh to give the rings a chance to bed correctly.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5883680
Hi thanks for your reply power goal 200-250 rwkw.Taking crank head and block to machine shop tomorrow 2 have them checked i will probably go with a rebore. The reason i want forged bottom end i cracked one of the original pistons and dont want the worry any more. The car will be driven normally 95% of the time and unleash it now and then.
I was also looking at oil pumps and it seems there are as many pros and cons with them not to mention huge cost. Might stick with the K.I.S.S protocol and stick with a standard item.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5883804
After your rebuild the main thing to keep your engine alive is a good tune. Have you got some kind of aftermarket ecu? If not z32 ecu with Nistune chip would be the minimum (and adequate for those power levels) followed by PFC or best a Link/Vipec.
Sorry just reread your post and see you have a piggyback - something like an e-manage would be fine.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5883864
why are you even bothering to rebuild if that is the only power you are after? I ran 300rwkw with a Garrett GT3076 for about 3 years, and when we removed the motor, it still tested perfect in a compression and leak down test.
I wouldn't even bother with a rebuild for your power goal unless the motor is already buggered.
ALso, DEFINITELY get the motor rebored if you are installing new pistons and rings. Forged pistons are sentisive to the right bore size.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5883952
It seems even with a standard oil pump,oil restrictors are advised, 20 bucks a restrictor, there are a couple of billet gear pumps in the parts for sale section. Price of these items will be small fraction at end of build.For your goals, quitting while ahead and buying a used RB25det for $1400 looks good. (price of retail after market oil pump).
Edited by WHITE gtt
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5884158
Hi bob thanks for the info left head crank and block at machine shop will get the news tomorrow on condition of items
Sam....
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5884711
Hi thanks for your input yes its a low pwr outlook at the moment but like to leave room for the futurei have extra mods id like to do in the future so thats why i want a reasonable bottom end.
I would also like it to run the car on a lower octane fuel somewhere in the future.
The original motor was going great never used oil went well no problems then i accidently filled the car up with regular unleaded in canberra and the car was lucky to make it home. Number 3 piston nearly parted company with itself split around oil ring recess was blowing smoke like no tomorrow.I dont want to change engine block as i like to keep the car,s main components original. You never really know what you are getting buying second hand.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5884743
ok no worries mate, didn't realise that you blew your old one.
Take my advice and experience - When you have the block out, get it acid bathed, decked, bored, hone, and the top of the bores chamfered. Should cost you about $300. And you'll have a peice of mind. Trust me, don't skimp in these areas. Especially if you are looking for bigger power later on.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5884749
And when a rebuild gos right, there is a special satisfaction.Oil control mods are a reliability mod, needed just as much as forged parts.
Edited by WHITE gtt
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5884770
Thanks for your advice has been taken on board just the type of info i was looking for.
I like doing my own rebuilds i have done plenty of engines over the years.
What is your view on oil restrictors to the top of the engine do the lifters suffer ????
thanks Sam....
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5884931
Three head oil feeds on an RB25, two block feeds to head, one for VVT. If you restrict two block feeds, you still have three feeds to a hydraulic head. People have adequate cylinder head oil with the VVT feed, one blocked, one restricted.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5884958
I put 2 x 1.3mm restrictors in the block feeds, and welded the head shut on the third feed because I used a RB30 motor. (Doesn't have a third feed for vct). I did the internal pin mod, and robbed 1.5mm worth of feed from the head journal on that side.
Didn't have a single issue with oil what so ever.
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5885262
Hi is there a thread on here or website that has info on oil restrictors
also would i have to put restrictors on all 3 oil feeds ??
sorry about all the questions just that id like to get it right
first time.
The car wont see any track work maybe occasional day at drags
and normal driving
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5894699
http://www.skylinesa...-drag-or-drift/
This is Sydneykids take on oil control. it seems most RB devotees support oil restriction in a rebuild.He advocates blocking an oil feed in the RB25. Mine and the Mafia is restricting the 2 block feeds.
Edited by WHITE gtt
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5894716
  • 4 weeks later...
Update engine build.
I have most of the parts to do my engine rebuild i have
1 set of CP forged pistons + rings pins clips 8.5:1 compression
1 set of Manley con rods/ARP 2000 rod bolts
Nitto Oil Pump +Crank coller
Cometec Gasket set
ARP Head studs
ARP main studs
New Timing belt + idler and tensioners
Engine block i have left the vvt restrictor alone blocked the middle restrictor and installed a 1.5mm restrictor in the rear
Block Head and Crankshaft now at machine shop for chemical clean head surace decked bored and honed and crank coller installed
Waiting to find out what size bearings will be needed
I hope i have not missed anything looking for more input to my rebuild and looking for any more info on anything i may have missed
thanks
Sam...
https://www.sau.com.au/forums/topic/369086-rb25-rebuild/#findComment-5941573
    • I'd want an even MORE side on view. More or less you want to make sure the outlet is actually square with the outermost part of the bumper. Or you end up getting soot all over your bumper from your hektik exhaust. In any case, it looks pretty close. I think the way to fix this is probably more of an overhaul at an exhaust specialty shop if you want tips that are rounded off or sit nicely with the bumper but have proper clearance and don't move - Probably more of a redesign than a quick fix. I've pencilled in my own exhaust with its own various problems, pinholes, PITA fitment, and other issues and can see myself going to a shop and saying "JUST DO THIS BUT BETTER?"  Which is gonna work better than any more small fixes. I'm gonna chime in here officially with "from an outsider perspective this exhaust looks fine so this is self OCD probably" (which I also suffer from)
    • Reminds me I really need to install that HKS oil cooler I bought years ago.
    • It be 40°C outside lately. 10W60 is a good idea here. Well, certainly 10W50.
    • Here are some side on's.
    • I just did an oil change on my daily which used oil that is probably 2-3 years old. Normally I try to follow exact viscosities, but my LS400 is fairly tolerant. Dumped something like half a quart of 0W30 Mobil1 ESP X2 in there, followed by 2 quarts Pennzoil 5W30, followed by ~1.2 quarts of liquimoly 5W30 LL04 spec oil. Then the rest was QS euro 5W40 which is actually so thin it's basically a 30 weight oil. All this is to say it doesn't matter that much. We aren't talking about brake fluid. For an RB I would recommend a high ZDDP oil because it doesn't use rollers in the interface between the cam and valve, but a 5W30 or 5W40 is fine to use for street use. The 10W60 guidance really only applies if you're getting it hot and pushing the engine hard.
